Page 18 of 18 FirstFirst ... 8161718
Results 171 to 178 of 178
  1. #171
    PWCToday Guru 08SilveradoOnRims's Avatar
    Oct 2009
    Florida
    Re: b1 155 pump ... jet dynamics
    Quote Originally Posted by SBrider View Post
    1100 ran great again today, but i had more fun on the built 760, was only 1 mph slower, but seems to hit harder on the low end, here is some pics of the ski, sleeper style,
    What's done to the 760?
    Sent from my EVO using Tapatalk 2
  2. #172
    PWCToday.com Is My Home Away From Home SBrider's Avatar
    Nov 2009
    santa barbara/redding
    limited pipe, lots of porting carbon reeds a prop and head, was running amazing today, been havin issues with it all year, and the first hour today, suddenly it came alive and ran the best it ever has.. idk ran some octain boost in it but didnt seem to kickin untill 30 min of ride time,
  3. #173
    PWCToday.com Is My Home Away From Home garrcass's Avatar
    Jun 2011
    Redding CA
    17
    Haha you just poured some toluine in it and cleaned out your fuel system they don't make real octane boost anymore might as well buy av gas its probably only $5 a gallon right now..
    ( Girlfrends are cheap X2,s are expensive )
  4. #174
    Nov 2009
    ya i figured cleaner and booster is the same chit, but i figured it would slow down the burn just a bit to stop it from detonating, but anyways something worked today on that mix, ski ran the best it ever has, goin out again tomor, you down ??
  5. #175
    Jun 2011
    Redding CA
    17
    Sunday bouys at the river early untell late.. I have to work on some outlets tomorrow while I have this horizontal band saw.
  6. #176
    Nov 2009
    mmmakay well i will be at jv, where can i get av gas ?
  7. #177
    Jun 2011
    Redding CA
    17
    Just go to the redding airport take the first left towards the redding jet center and turn left into the place at the end of that road across from redding jet center and tell them you want some av gas that's where it used to be its around there somewhere.
  8. #178
    Nov 2009
    at it again, this time a rocker kit and i widened the mouth , 7/14 prop, i kinda rushed the glass work because i was pressed for time, i will clean it up over the winter, extremely impressed with my results ... hooks up instantly launches great, does hold the motor back a bit. had to press the mid shaft back over an inch to get %100 of the splines to touch, had the mid shaft turned, spacers on the shaft and motor side to get them to line up.
