Results 11 to 13 of 13
    Mar 2010
    Down by the river
    Re: Jdpilot- Backup/spare/copper x2 refresh build
    Suncoast used to advertise these in PWI in the mid to late 90's. Not sure if I could find an ad, will look at the issues I still have... Always thought this was a cool idea.
    Jack,
    You should be able to make one using a stainless steel pneumatic cylinder. There are other brands, but this reminds me of a Bimba cylinder.
    http://www.bimba.com/Products-and-Ca...Line-Cylinder/
    Jdpilot,
    Are there any markings on the other side of the cylinder, or do you have the OD of it?
    These are pretty modular, once you know the bore and stroke of the cylinder, you'd be off & running. You could even make a "hydraulic trim" setup with a handlebar mounted valve that lets water in & out of the cylinder. With the valve closed, the nozzle would remain stationary regardless of throttle
    Oct 2012
    Belgium
    Quote Originally Posted by spxfanatic View Post
    Jack,
    thanks for the info's , any pics of your syst ?
    PWCToday.com Is My Home Away From Home jdpilot's Avatar
    Sep 2006
    New Hampshire
    Updating the ongoing (loooong and sloooow) build thread. After head install above, I reaped 45.1 on the Garmin. Added a bored group k Nozzle today and an aluminum impeller boot to smooth out the flow. New GPS results coming this weekend. Not expecting much, but curious nonetheless.,
    Prospect Mountain Powersports
    Altitude; 653
    Limited 87 650SX- 43.6
    Limited 93 X2- 45.1
    Limited 87 hull/86 internals X2- 43.7
    92 WR3- 37.0
    93 WR3 w/Shuttlecraft JetSport
    94 WB1- Limited
    09 superjet- stock 1 owner
    88 WetJet 432- stock 1 owner
    87 X2- stock 1 owner
    82 js440- stock 1 owner
    92 js440- stock 1 owner
    85 js550- stock 1 owner
    85 js440 super stock- Expert Womens Class
    85 js440- super stock- Region 8 Novice
