Jdpilot- Backup/spare/copper x2 refresh build
Results 1 to 10 of 13
    PWCToday.com Is My Home Away From Home jdpilot's Avatar
    Sep 2006
    New Hampshire
    Yup, I know, its shocking. But, I have FOUND time to continue with a build. It officially starts today due to lack of snow. I am pulling the copper/backup X2 off the rafters today and onto the surgery table. Reminder pix;
    I went from this;
    To this;
    Then lastly this (optional pontoons for the wife (Thanks Joe)/ and new bars (Thanks Glynn)/Limited Surf slam copper blowsion grips/finger throttle/UMI base on stock stem/renthal pad// 15.5 prop, coffman pipe, bad bones reeds, DG intake mani, bilge, west coast tank);
    So the plan. I originally wanted to keep this as a no nonsense boat. HA! that didnt last. This will be a lake boat. Built as a buoy chaser for fun. I want to have a similiar riding experience to my surf boat, without the noisy water box, and different handling characteristics for fun. Surf boat has an uptrim installed. This will have a drop nozzle. The box of parts I have been collecting for this build since the end of summer, that will work with the mods I added last year, includes;
    -A red 42mm Keihin carb. Sent to group K for the work I always have done to my 42s (bored seat to 2.0)
    -NOS mariner reed stuffers
    -Ocean pro intake filter
    -Stock head I sent to group K. Was machined for 185 using their "sleeper" mod. I just drilled the dual cooling boss yesterday
    -Extra fittings for dual cooling on the pump
    -Extra fittings to tap the stock 93 diverter exhaust manifold for dual cooling
    -Rebuild kit for carrier bearing
    -Rebuilt kit for pump
    -Stock nozzle I sent to group k for their "sleeper" mod boring
    -Stock flywheel I sent to group K for "sleeper" mod lightening
    -New bendix
    -New starter
    -Newly redone JSS coil and stator
    -Wet wolf stubby nozzle cone
    -Heres the fun one for buoys (or in my case moorings lol). Suncoast NOS drop nozzle kit. (Works with stock trim. Set the trim where you like, then at WOT a small piston pushes the nozzle full down.
    Should be a fun project. Not too drastic, could be done in a weekend. But I plan to putter on it evenings til spring. Pix to come...
    And no... The SJ is STAYING stock lol...
    Prospect Mountain Powersports
    Altitude; 653
    Limited 87 650SX- 43.6
    Limited 93 X2- 45.1
    Limited 87 hull/86 internals X2- 43.7
    92 WR3- 37.0
    93 WR3 w/Shuttlecraft JetSport
    94 WB1- Limited
    09 superjet- stock 1 owner
    88 WetJet 432- stock 1 owner
    87 X2- stock 1 owner
    82 js440- stock 1 owner
    92 js440- stock 1 owner
    85 js550- stock 1 owner
    85 js440 super stock- Expert Womens Class
    85 js440- super stock- Region 8 Novice
    I dream skis DontYellAtMe1's Avatar
    May 2011
    Grand Rapids, MI
    Could you post pics of the drop nozzel kit?
    Sep 2006
    New Hampshire
    Re: Jdpilot- Backup/spare/copper x2 refresh build
    Quote Originally Posted by X2Lobster View Post
    Ditto
    Will do. Pulled it off the rack yesterday. Not touching it today but i have tomorrow off and will snag pix of the kit and instructions. You're gonna dig how simple the kit is. It's one of those "why didn't i think of that" kits. Never seen one in use and have only seen a couple on ebay in the last 7 years.
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Sep 2006
    New Hampshire
    Drop nozzle pix WITH instructions (the small piston extends almost an inch);
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Sep 2006
    New Hampshire
    Here are all the other parts I have accumulated for this;
    Group K head, Group K flywheel, NOS stuffers, Group K modded 42mm;
    Group K nozzle;
    Goki X2 wires, Fun side rail grips;
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    I dream skis Camaroz28850's Avatar
    Aug 2009
    Hudson NH
    I have never seen the automatic drop nozzle. Very cool part! Sounds like you will have a nice back up X2.
    This thread makes me want to start a build thread for the project I have been slowly working on.
    Resident Guru X2Lobster's Avatar
    Mar 2007
    ME/NH
    Wonder if you could set that piston to push the nozzle up when you throttle it off a wave. Cool piece though!
    Sep 2006
    New Hampshire
    Tinkering slow but sure. Sprayed my group K milled head with copper engine enamel, matches the copper highligts on the boats exterior. Didnt bead blast it as I should have, so its not perfect. Just spot sanded and acetoned it. But who cares, its a head that wont get much sunlight anyway.
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Sep 2006
    New Hampshire
    Finally popped the group k milled head on her today. 145 psi stock on original 1993 motor that's never been apart. Now pushing a "cautious" 165psi. jugs looked pretty good. Resealed with a new gasket and 1211
    Altitude; 653
    Limited 93 X2- 45.1
    92 WR3- 37.0
    94 WB1- Limited
    Oct 2012
    Belgium
    Quote Originally Posted by jdpilot View Post
    that looks realy cool , whant one !!!! any idea ? thanks Jack
