jet size on stinger pipe? effect?
    Resident Guru mandriva's Avatar
    Sep 2009
    montreal,quebec
    hi, I would like to know the role of the main jet in a stinger pipe? just keep cool hole rubber or real gain performance? for aftermarket pipe like factory pipe spec 1, and 2 and rossier also!!
    thank
    Rossier 7250 rpm
    110 mid pipe/200 stinger
    185 psi/Head 41cc/43squish
    Solas concord 15/23
    Top Dog Russell2sx's Avatar
    Oct 2009
    socal
    It depends on the stock opening into the stinger...my Coffman dumps a 3/8" line straight in so a ton of water hits the waterbox and steals power,I put a small ball valve on it so I can adjust the flow and yes it makes a pretty big difference
    Frequent Poster cr21sparky's Avatar
    Aug 2011
    Weatherford,TX
    Re: jet size on stinger pipe? effect?
    Before I had ecwi I had a jetworks control valve I shimmed it so at about 4000rpm
    It would start shooting water into waterbox. Had 130-150 jets
    Casey
    WWW.NEVERSATISFIEDMOTORSPORTS.COM
    1997 SEA DOO SPX jdyn grate,vtec,beachhouse,miller head,spec1,skat sw17-22,wc nozzle,umi,44blackjacks,TNT ecwi,tdr-wb,microtouch,needs more!!!
    2010 KAWASAKI STX 15F r&d grate,r&d power filter
    Sep 2009
    montreal,quebec
    update this topic....I was experimenting with changing the amount of water flow to the
    stinger on a rossier this weekend. Results were different
    than expected. Drying out water to the stinger resulted in about 70-100
    less max rpm, but EGT's dropped about 100 degrees!
    My testing results are correct. When you reduce the water at the stinger
    it then appears "larger" (less pressure) to the sonic wave. This will lower
    the rpms, increase torque and also reduce your EGT. When you increase water
    at the stinger the results should be opposite.and While you will get the results you now are expecting please be cautious as
    extra water in the stinger at high RPMs can lead to detonation as the result
    of higher pipe pressures ( higher trapping efficiency).
    rossier recommand keep under 180-200 main on stinger
    Rossier 7250 rpm
    Solas concord 15/23
    Nov 2015
    itlay
    Quote Originally Posted by mandriva View Post
    please could you explain what does it means a 180-200 jet (1.8-2.0 hole diameter in mm?) and wich is the water with whom i could make calculation about the water flow.....
    hope u understand me
    Nov 2015
    itlay
    Water pressure i miss a word
    Riverside, CA
    6
    When you increase water at the stinger the results should be opposite.and While you will get the results
    you now are expecting please be cautious as extra water in the stinger at high RPMs can lead to detonation
    as the result of higher pipe pressures ( higher trapping efficiency). Rossier recommend keep under 180-200
    main on stinger
    I agree with this statement, but many people lean towards modifying the stinger to a larger
    (safer) diameter. But I do not agree that it is ever a single source for detonation if the pipe
    is setup as recommended. (But I believe that is what mandriva was trying to say)
    There is the possibility that using dual cooling lines may cause, or add to a list of problems
    when the owner uses a single line to supply the exhaust system.
    A 440 pump supplies 30 psi of flowing (not static) water pressure. A 750 supplies 40psi, a
    900 supplies 50 psi.
    When you use a single line to supply an exhaust pipe, you are increasing the water pressure
    at the headpipe. When you increase the pressure at the headpipe, you are increasing the
    pressure at the water bleeds and create more torque because you are lengthening the pipe.
    You are also increasing the water pressure at the stinger, and that can be good or bad.
    Not sure I agree with this, maybe it is just the terminology. Mainly because the stinger diameter
    influences how the pipe scavenges fuel air mixture inside the engine. It is similar to a control
    valve.
    Gordon Jennings said that when the stinger is too small, it will cause the piston crown to
    overheat and detonation will occur.
    But what really happens, is when the stinger is too small, a portion of the hot spent gases
    (exhaust) is unable to escape. The hot spent gas backs up into the exhaust port and mixes
    with the incoming fresh air-fuel mixture.
    Since the hot spent gases can not be burned twice, the engine looses power. The hot spent
    gas also preheats the fresh air fuel mixture, the engine looses power, and combustion temps
    increase to the point of self ignition (Detonation).
    It is the hot spent gases that heats the piston crown, and how fast the piston crown is heated
    is dependent on other factors.
    Normally stinger diameter is a variable left to the designer or R&D tech.
    Water routings on a pipe should only be done after the impeller, and jetting allow the engine
    to easily make or exceed peak HP rpm at wot.
    Bill M.
