light bulb
Results 1 to 10 of 10
Thread: light bulb
    Sep 2012
    NC
    light bulb
    Any thoughts on putting a small 60 watt light bulb in the engine compartment - just in case ALL the water was not evacuated during the RV antifreeze procedure? Then only turn on during extremely cold nights.
    Jun 2003
    JACKSONVILLE FL.
    Re: light bulb
    I use only small 800 watt thermostaticly controlled electric heaters in mine with the tipover switch taped over and they work very well. The draw no power unless the hull goes below 40 degrees inside. If the power goes off, my house generator kicks in.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
    I dream skis rhaas's Avatar
    May 2008
    bay saint louis, ms
    Re: light bulb
    I put a string of christmas light in mine when the temps get low, they heat up the inside of the engine compartment just enough without risk of anything burning up. just make sure they are not led lights, I use the cheap dollar store kind.
    RHAAS PRODUCTS
    urethane motor mounts for watercraft... its about time!!
    http://www.facebook.com/#!/pages/Rha...12717472096935
    try our new website
    http://www.rhaasproducts.com/
    stay tuned for more products
    PWCToday Regular bikerboy's Avatar
    Sep 2002
    on the ice cube or the water
    Re: light bulb
    I live in Minnesota and both my skis are stored outside during the winter. I have had my 03 since new and it has seen -20 degrees with no issues. I just follow the normal winterizing procedures as outlined in the manual.
    Sep 2012
    NC
    Re: light bulb
    Thanks guys for all your input. I did do the regular winterizing procedure, but had trouble getting rv antifreeze out of the pisser ( or for that matter , anything out of the pisser). The light should work well. Merry Christmas to all.
    PWCToday Regular pepe-2327's Avatar
    Jul 2011
    Key Largo, Florida
    Re: light bulb
    Quote Originally Posted by dupont View Post
    You can use a drill pump with enough antifreeze, it will go out of your pisser.
    ______________________________________
    2012 Sailfish 2680 CC
    2 2013 SeaDoo GTI SE 130/155 "The New Toys"
    2 2003 Honda F12-X "SOLD" "Gone but never forgotten"
    Frequent Poster EricDen's Avatar
    Sep 2011
    Orange Par, FL
    Re: light bulb
    One thought. Caution using any type of pump...The idea behind the gravity fed system and specific amount of anti freeze is to keep liquid from pushing back into the engine. Same reason you don't pressure the cooling intake until the engine is already running.
    2-2008 Yamaha VX Delux
    2015 Polaris Slingshot
    2015 F150 4x
    3 Kayaks
    No time!!
    Top Dog teamzulu's Avatar
    Oct 2007
    Southwest MN
    Re: light bulb
    Seems like over kill to me.
    94 WB w/extras -Wetness Specialist
    94 FX-1 w/extras -
    Get It Up, Stick It in
    95 WB Stock
    96 WB w/extras
    Jul 2002
    near Detroit, MI
    Re: light bulb
    If you're worried about backing up into the engine, pump the antifreeze in with it running. It will only take a few seconds.
    Current Ski:
    '04 R-12x Black, ~160 hours, stock, 61.7 GPS
    Dad's Ski:
    '04 Polaris VirageI, ~110 hours, stock
    Former Skis:
    '04 Ultra150, Stock, Sold @ 104 Hours 63.5 GPS
    '98 1100 ZXi, Skat Trac 13/18 Swirl, Temp Sensor Mod, Hours??? but more than the Ultra. 55.0 GPS
    Jul 2011
    Key Largo, Florida
    Re: light bulb
    Quote Originally Posted by EricDen View Post
    That is why I recommend a drill pump, you can control the drill rpm's.
