Hello,
I am hoping you can clear things up regarding the timing curves of the sx/sxi and their years. This is all in regards to running the R&D advance plate and if it is safe to do so on the sx, sxi, sxi pro.
Do all the big pin dual carb sxi's have the same timing curve. From what i've been able to read is that the 95sxi's differ from the 96 and later years and that all the sx's are the same... is this true
I guess this all boils down to is if the advance plate is worth the potential trouble of toasting an engine if the tune is not spot on or you get some bad gas.
I have a 95 sxi and am now questioning running the advance plate or not
Any insight would be much appreciated
Comment
