high compression head - Page 4
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
  1. #31
    PWCToday Newbie kvogt8000's Avatar
    Apr 2011
    pittsburgh, pa
    I also am running the stock ignition and the air temp. Bypass.... I plan on adding the advent this summer.
  2. #32
    Apr 2009
    Boston
    Re: high compression head
    I am running the stock ignition with the temp bypass. The purpose of adding the Advent ignition would be so I could select or have a custom curve made for my application. I figured this would help my motor with the increased compression. I'm really trying to figure out the compression differences between the 29's and 28's that TBM sells.
  3. #33
    PWCToday.com Is My Home Away From Home jetman624's Avatar
    Nov 2003
    South OC, CA
    If your motor has not been decked or ported, TBM should be able to give you pretty close compression numbers. If either of the aforementioned have been done, you are on your own.
    Have you popped your head to look at the domes and make sure you aren't detonating as is? ANY sings of detonation would mean that you are on the fringe of pump gas for your compression and timing-- adding more of either would almost certainly spell trouble.
    '02 SXi Pro: Factory Limited pipe, ported SXR cyl, SSP stearing system, WORX ride plate, skat trak intake grate, blowsion tubbie II, 3DR SS hull extensions, 3DR trued hull, 3DR pump shoe mod, bored pump nozzle
    '92 X2: Mostly stock, except for the 750
    '91 X2: #718
  4. #34
    Sin City USA
    Use of the temp sensor bypass with increased compression is begging for detonation!
    Advent is the way to go, a real timing curve will make all the difference.
  5. #35
    Apr 2011
    pittsburgh, pa
    good thing for you guys and this forum.... i onlyran mine on the hose for a lil, but ill be disconnectiong that bypass. anybody got a line on an advent ign. new or used
  6. #36
    Top Dog mattyv's Avatar
    May 2009
    Long Island, NY
    I ran my 800 like that with no deto problems. Maybe I just got lucky
    Sent from my C771 using Tapatalk 2
    108
    www.eastcoastwatercross.com - Region 8
    #teamlogan
    CT Watercraft
    ZForce Racing
    Jettrim
    Slacker Graphics
    Champion Honda of NY
    Prowatercraft Racing
    Jet Renu
  7. #37
    Nov 2003
    South OC, CA
    The advents don't mean automatic safety. Depending on the curve you have, you can still heat up the motor and cause problems if you are putting around in an RPM range that has a lot of advance. You are walking a fine line with pump gas, increased compression, and advanced timing curves. You would be wise to error to the safe side on compression numbers if you want to run an aftermarket CDI.
    '91 X2: #718
  8. #38
    Sin City USA
    Quote Originally Posted by mattyv View Post
    I ran my 800 like that with no deto problems. Maybe I just got lucky...
    Maybe you did. Its a known fact that running the temp sensor jumper with higher compression puts you right on the edge. Just one tank of sh*t gas will let you know Ask me how I know.
    The advents are awesome but jetman is right it doesnt mean automatic safety. You have to use the correct impeller so you can attain your motors peak rpm. If you have too tall of an impeller and it drags your rpms down, you risk deto from being in the rpm range where the timing is very advanced for too long. Advent has a curve for virtually every setup you can build.
  9. #39
    Apr 2009
    Boston
    Were you running the TBM setup? Was it the limited setup? Did you use an after market ignition? Stock pipe?
    Do you recall what your compression was?
    I just tore down my motor and it looked great with 3 years of running. Domes and pistons looked good.
  10. #40
    May 2009
    Long Island, NY
    R&D 29cc head, .5 mm bore, stock pipe, stock ignition w/jumper. I think it was around 180. No issues. Only had it like that for about 2 months though, then swapped back to a stock head
    108
    #teamlogan
    CT Watercraft
    ZForce Racing
    Jettrim
    Slacker Graphics
    Jet Renu
