FX-1 Bogs when doing tail stand.
Results 1 to 2 of 2
    Frequent Poster JSmith5690's Avatar
    Jan 2006
    Mobile, AL
    I posted this in the fx1 section as well, but this section probably gets more traffic so I am posting here too.
    My fx1 bogs when doing a tail stand. I don't think it's fuel related (but I could be wrong). It acts as if the exhaust is very restricted. Once it gets back tilted about 45 degrees back to horizontal, the bog clears and runs fine.
    Ski runs great other than this. Has b-pipe but otherwise stock.
    By the way it's not an issue with low fuel, tank was full.
    Thanks for any advise offered.
    __________________________
    '96 Blaster--Riva Red Pipe, UMI Bars/Steering, Protec Plate, R&D Grate, JetTrim Seat
    '94 Blaster--Restored to '96 OEM Graphics and Colors, 760 engine, Dual Buckshot 44's, Factory Drypipe, Factory Pipe Waterbox, Rideplate & Grate, Hydroturf Mats,Magnum Pump
    '95 FX-1--"Real" FX1 B-Pipe, Ride Plate, Intake Grate
    '84 JS440--w/550 engine, Custom Paint, Kerker Wetpipe, SuperTrapp, UMI Bars Turnplate & Trigger, OP Nozzle and Steering Nozzle
    '96 GTX
    '94 XP
    Trinity Epic X-2
    Re: FX-1 Bogs when doing tail stand.
    Sounds like a waterbox problem. Either too much water in it or a broken baffle.
