How to dry out your Kawasaki 1100 exhaust system
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 114
    Resident Guru Watrboy33's Avatar
    Jul 2007
    SoCal
    Sounds pretty simple, you want to dry out the main expansion chamber and add cold water to the exhaust stinger for more RPM. I have compiled some diagrams and advice from a few members on here and took pictures along the way. My install was on my conversion Waveblaster with Kawasaki 1100, but I'm sure this will work for the SXR as well.
    Parts:
    1/4" brass threaded hose barb (1/8" thread)
    Mikuni 120 main Jet
    8-32 x 7/16 SS hex bolt
    8/32 Tap
    M5 x 0.8 Tap
    1/8" NPT Tap
    (2) 1/8" threaded brass plug
    "R" drill bit (11/32)
    1/8" x 3/8" brass threaded hose barb elbow
    1/4" x 1/2" brass threaded hose barb elbow
    3/8 x 3/8 x 1/4" barbed "T" ( I used plastic, but would prefer brass)
    1/4" water hose (1 foot)
    1/2" water hose (4 feet)
    3/8" water hose (4 feet)
    Teflon tape
    3/8" & 1/2" SS hose clamps
    Tools:
    Tap handle (small and large is good)
    Cordless drill
    Shop vac
    Dremel
    Sharpie
    hand tools (sockets, screwdrivers, etc)
    1.) I started with the 1/4" threaded hose barb install. Drill at about the 3:00 position (pipe upright) with Type "R" drill bit 11/32. Tap with the 1/8" NPT tap, install your hose barb.
    2.) Next I tapped out the inside chamber (top of expansion chamber where stock water elbow was installed) You don't need to drill this out, just use the 8-32 tap and don't make it too big as the inner chamber wall is very thin. Install the 8/32" SS bolt with red threadlock and snug.
    3.) Use 1/8" brass plug for upper threaded hole.
    4.) Remove brass fitting in front of head pipe (1/4" line) I used a pair of vise grips and twisted a few times, came right out. Drill out this hole about 1/4" or so with Type "R" drill bit 11/32, tape with 1/8 NPT tap and install brass plug.
    Jan 2011
    Ct
    Re: How to dry out your Kawasaki 1100 exhaust system
    (Erased dumb question)
    Frequent Poster kawasaki9's Avatar
    Sep 2011
    Melbourne Australia / Portland Oregon
    Great Thanks mate !!
    Jan 2011
    Ct
    Oh I see it now
    Jul 2007
    SoCal
    You will have to tap the stock manifold for dual cooling. My Blaster has a 1/2" line going to the stock position on the manifold, my boat came with dual cooling, the second line being a 3/8" line, which works out good for this install. I left the exhaust manifold installed on the engine and found a spot with good clearance from the starter and expansion chamber. I marked this spot blindly with a black Sharpie pen (see pics)
    I removed the manifold and drilled out a 11/32" hole, then tapped with the 1/8" NPT Tap. Installed the 3/8" barbed elbow pointing back around the stock 1/2" fitting.
    Next I slipped the manifold on the block and measured the water lines to the pump fittings and cut to size. Then I placed the expansion chamber on the manifold and measure out the spot for the 3/8" x 3/8" x 1/4" "T" fitting and cut the 3/8" incoming water hose to match.
    I will get some of these pictures posted on Photobucket for you guys.
    Jul 2007
    SoCal
    Jul 2007
    SoCal
    ^^The picture above was sent to me by another member on here ^^
    Kawasaki 9, I used the stock 1/2" elbow on the exhaust manifold and added a 3/8" elbow in the forward position (see pics) As far as water routing, I had a 3/8" and 1/2" water line coming from the pump. The 1/2" went straight to the manifold (stock routing) The 3/8" line has a "T" fitting right next to the exhaust stinger and a 1/4 line is run to the 1/4" threaded barb fitting. The line then keeps going to the manifold.
    Also, don't forget to take the M5 x 0.8 pitch tap and tap out the inside of the 1/4" barbed fitting in the stinger. This allows the Mikuni jet installation in the top of the barb.
    Oct 2009
    Jersey Shore
    Make damn sure, whatever line you are jetting has a strainer/filter before it!
    One tiny spec of chit, is all it takes to clog a jet and end your day!
    Jul 2007
    SoCal
    Quote Originally Posted by Chris03HD View Post
    Good advice, I was thinking about that as I looked at the 150 jet I'm running.
    What do you think of something like this on the incoming 3/8" line?
    http://www.atlanticjetsport.com/inde..._detail&p=1474
    Oct 2009
    Jersey Shore
    Exactly.
    My favorite place to shop too! (15 mins away)
