HELP!!!! Js550 stator problem
    PWCToday Regular Jetski61's Avatar
    Feb 2012
    Illinois
    Hi guys it's been awhile, a new hunting dog has taken up most of my time lately. But anyways I'm looking for a stator in good condition with uncut wires. But I was also wondering if there was a way to rewire the stator I already have, because it's brand new its just the wires were cut so now I think that my connections are not good enough for the stator to work properly. And if they could be required how would I go about doing that? Help on this matter would really be appreciated.
    Frequent Poster gogetinkdone's Avatar
    Jul 2012
    billings montana
    Re: HELP!!!! Js550 stator problem
    just solder the wires and make sure you tape them well. I dont think that will cause any problems. Save your self some $$$.
    Mar 2007
    Is Everything!
    Shrink wrap the solder connections with self sealing shrink wrap. The pins can be purchased at radio shack, Fry's, etc and installed with a pin crimper available at any tool store worth its salt.
    Feb 2012
    Illinois
    Ok thanks guys. One more question. What solder should I use? Because the general solder I tryed to use before wasn't holding it kept falling off.
    Jul 2012
    billings montana
    +1 on the shrink tubing. i use rosin core electrical solder that i bought at radioshack. you may need to use some flux if its not holding.
    PWCToday.com Is My Home Away From Home wielgot's Avatar
    Jul 2011
    chicago
    where in IL are you i can help you if you are close
    IL Jet Riders Member #2
    95 X2 650
    92 Jetmate ported 750 factory pipe
    92 SC 750
    93 Blaster stk
    93 Blaster Mod
    Paypal= jwielgot@gmail.com
    Resident Guru xpmr5's Avatar
    Jul 2010
    Elwood, IL
    If you do not have access to solder or a solder gun, heat shrink butt crimp connectors will do the trick:
    http://www.amazon.com/American-Termi...t+shrink+16-14
