Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 73
    Oct 2012
    Belgium
    Re: Group k air fuel seperator
    One like this one? I included the instructions in case you don't have them.
    sorry to ask , but what's the use of that ?
    Only work for dual carbs ?
    thanks
    Jack
    SE MI
    The tube is empty. As the fuel gets pumped in through the two brass inlet barbs the upper outlet (plastic) allows the return of any air that was pumped. The bottom outlet (also plastic) is the fuel feed line to the carbs.
    Frequent Poster mrgoodwrench's Avatar
    Jul 2012
    zimmerman mn
    Thats kind of how i was picturing it but just thought their might be more to the magic inside. I get it now thanks blrider
    SE MI
    Quote Originally Posted by JHR View Post
    thanks
    Jack
    This is used to removerify air bubbles from the fuel flow. It works with either dual or single carbs.
    SE MI
    Quote Originally Posted by mrgoodwrench View Post
    Simple magic.
    Glad to help
    Oct 2012
    Belgium
    thanks for the info's
    Is that a must for dual carbs , on one of the pics , i can see a fuel restrictor , is it for the return ?
    that kit is made for one pulse for 2 carbs correct ?
    I run the same remote fuel pump for my single 44 Boswell with pump plate block off
    SE MI
    Yes, the restrictor is for the return line. The fuel pump has one pulse and two fuel exits. This fuel separator would go between your pump and your Boswell (that has the pump plate block off)
    Oct 2012
    Belgium
    don't whant to puch , but where can i find the fuel line routing of that kit , can't put my finger on how they trap the bubbles
    thanks for your patience Kurt
    SE MI
    Hope this helps.
    Jul 2012
    zimmerman mn
    What fuel pump do they use in the kit i might order it without the pump if i have one laying around.
