Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 162
    Aug 2012
    Illinois
    blown head gasket?
    1996 daytona 770.I was flying down the river when all the sudden the jet ski quit pumping water. I was stupid and the motor got hot. I cleaned about 2 pounds of sand out of the screen the next day. I took it back out and know it pumps water fine put acts like its running on one cylinder. It will only go about 20mph and acts sluggish. i did a compression test. 135 on one cylinder and 95 on the other. any help would be appreciated.
    PWCToday Regular alexb757's Avatar
    Jun 2011
    New England
    Re: blown head gasket?
    You have to take the head off to investigate that "95" reading.
    Aug 2012
    Illinois
    Aug 2012
    Illinois
    Aug 2012
    Illinois
    what you guys think? obviously that gasket is warped and a small crack. is this whats causing the problem?
    Jun 2011
    New England
    Replace the gasket with a new one and try another compression test. You might have found your problem.
    I'd also keep an eye on those pistons. There's not a lot of wash on the tops indicating a lean mixture. Could be from getting too hot from lack of water, or something else.
    Aug 2012
    Illinois
    Quote Originally Posted by alexb757 View Post
    thanks for the reply. my ski has always ran rich. so your correct about it not running lean. I hope this is the problem! Im not sure if this makes sense, but the 135 compression was on the piston without the little tear in the gasket.the 95 compression was on the good looking side of the gasket.
    Top Dog Swiss's Avatar
    Jun 2010
    Tulsa,OK
    PWC Sales/Service/Performance Grand Lake,OK
    922 N.3rd St. Langley,OK 74350 918-902-7876
    Aug 2012
    Illinois
    Im putting the head gasket on today. Damn i hope that this is the problem
    Aug 2012
    Illinois
    well, that didnt work.F! it is still doing same thing. the motor sounds good. It just pushes threw the water at 4.5 rpms and about 20mph. I met a guy at the boat ramp and he believed it was the wear ring is bad. I did clean about 2 pounds of sand out of it after it broke down. any ideas?
