    Sep 2011
    Novato Ca
    steering problem with ocean pro nozzle setup on 1990 X2
    Hi;
    I have a 190 X2 that has a ocean pro steering nozzle setup on it. It did used to turn decent with the stock steering stem. I just recently put on a UMI steering setup on it. I cannot turn very sharp at all.
    Things I have tried with the help of a jet ski mechanic.
    tried 3 different lower steering stem arms long ,med,short etc. ( not much difference)
    shortened steering cable a little bit to try to get a full throw. ( reached the point of can not trim any more)
    The mechanic said that I am losing turn radius because there is slop in the ocean pro pivot points on the steering nozzle assy. can this be repaired or can I buy a new one? Do they make one that has multiple places to put the steering cable knuckle fitting like a PJS? I like the nozzle please let me know what else I can try as I do not want to go back to a stock nozzle.
    Thank you
    Steve
    Sin City USA
    Re: steering problem with ocean pro nozzle setup on 1990 X2
    Steve post this in the X2 section also. I think that some of the 1990 models had "direct steering" which causes lazy steering. It is especially a problem with higher performance engines and aggressive nozzles, etc... There are fixes for this problem that will help you regain steering control, if that is in fact what you have.
    Sep 2011
    Novato Ca
    Thanks Johnny;
    I did post this in the X2 section of vintage skis I hope that I can get some good help on figuring this out. I really love that ski when it works right!
    Top Dog GreyGoose's Avatar
    Aug 2005
    Temecula
    I had the same problem my first time out. Here is what I posted on how to fix it. I know the search doesnt work on this site anymore.
    Found a cheap, easy solution to the x-2 direct steer bending. It was terrible my first time out on my 1989 x-2. http://www.amazon.com/gp/product/B00...ls_o03_s00_i00. $11 for a 12" piece. Then just slip a short piece of 1/4 hose inside the stainless tube to make it fit tightly around the small inner steering rod. The thin wall clear stuff from home depot fits perfect. Then you got a heavy duty fix for $11.07 with free shipping. It will actually turn left!
    Sent from my brick phone.
    Top Dog hooka-2's Avatar
    Nov 2005
    sebring florida
    You need to put a JRE 1 inch spacer between the nozzle and the pump. I just installed an Ocean Pro nozzle on one of my X2s and could not get the steering right. I added the spacer (kind of expensive) but works just like the PJS rip turn on my other X2's now. I get full throw both directions and handlebars centered when I go straight.
    90 X2 (750), 92 X2 (750), 93 X2 (750),93 X2 (750), 99 Ultra 150(sold) 1995 Waveblaster 1
