Best Ignition for SXR 800? - Page 3
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
    PWCToday.com Is My Home Away From Home garrcass's Avatar
    Jun 2011
    Redding CA
    17
    Re: Best Ignition for SXR 800?
    Quote Originally Posted by sxr951 View Post
    As a precaution, leave nothing to chance. Myself and NASA engineers have always insulated any bare wires in our Hydrospace standup skis electrical box with thin bike inner tube rubber. (Reason)~~> To avoid chafing thru electrical wires due to vibration against metal. Apply Dielectric grease to all the contacts slightly to insure good contact and deter oxidation and oscillation of electrical energy flow. Water proof grease to the o ring gasket on electrical box before assembly. and use water proof grease on the screws before assembly to avoid galvanic corrosion, be sure electrical box is grounded.
    This is good advice plumbing silacone grease is also the same as dialectric silacone grease. Also in a pinch this is going to sound Fawked up if you have to ask some one for some but. Vasilene is a great dialectric more putroleum baised so it breaks down and breaks down from heat. Just like oil gas or grease of a non synthetic variety.
    ( Girlfrends are cheap X2,s are expensive )
    Feb 2011
    oz
    Good to see ya on pwc today benny!
    Jun 2003
    Huntington Beach
    Anyone used this Venom ignition? I am looking at one for stock racing. Basically looking at increasing the rev limit and an improved timing curve.
    http://www.amazon.com/Kawasaki-Pefor.../dp/B00C0CLUYG
    Wanted: Job that involves riding, surfing, or sleeping.
    PWCToday Regular Marsig58's Avatar
    Feb 2011
    Perth, Western Australia
    Save the money and get an Advent. Or advance the timing with the jump plug like used with a factory pipe.
    PWCToday Newbie jairoc's Avatar
    Sep 2014
    Barcelona Spain
    I am thinking to use jsu, hpi or cdi-r in my sxr ski lites, someone has experience with those ignitions?
    Thank you
    Feb 2011
    Quote Originally Posted by jairoc View Post
    Thank you
    I nearly bought the cdi-10r. I think they are good ignitions. Possibly to the build quality of oem. I think they are preset with curves and not programable.
    Feb 2009
    france
    Run either curve 1 or 2 if you intend to run pump gas. 3 and 4 require race fuel, 104 and 109 respectively. Your rev limiter is fine at 8000.
    Here is the breakdown. The D4 curve-set is by Kommander Industries, all 4 are custom curves. If you want a copy of the actual curve mapping I can email them to you, as they are not available through the Advent website.
    #1 (SXR-1) is a "Limited" up to 185lbs on 91 octane fuel minimum.
    #2 (SXR-2) is a "Limited" up to 180lbs on 92 octane fuel minimum.
    #3 (SXR-3) is a "Superstock" up to 200lbs on 104 octane fuel minimum.
    #4 (SXR-4) is a "Superstock" up to 200lbs on 109 octane fuel minimum.
    Having said all that I do not know if your octane calculation methods there are the same as here in the USA! Make sure you are running the equivalent of the fuel octane ratings I specified, at or below the compression stated.
    Jonnyx2, i have a similar set up: sxr stock bore, domes head kommander 30cc, oem base gasket, 185 psi, wet pipe, stock carburetors, oem pump with tbm cone,92AKI fuel pump do you think it could work for my setup ( curve D4) ? can you send me this D4 curve please?. Could the SXI-21 and SXI-22 good too for my setup? thank you.
    Feb 2009
    france
    i forgot: 0,040'' squish gap......
  9. #29
    Sep 2002
    gold coast
    Just use a zeeltromic. Stop mucking around
    Www.waxracingproducts.com
  10. #30
    charlotte,nc
    id love to get a zeel, where can i purchase one from?
    96 superjet- rockered, -4, wide tray, adjustable footholds, kv148 mag setback pump, skat 7/14 impeller, rrp adjustable pole, blowsion ovp steering, 62t/62t, ada head, zeel A02T cdi, dual 44s, boysen power reeds, TNT SS chamber
    93-x2, newmiller ported SP750, milled head, R&D single 46 intake, sbn46, fpp blaster chamber pipe, hooker 9/15, umi, rhaas squirrel cage, dakine foot straps
