33 hours on f12x spark plugs... good / bad?
    Aug 2007
    Chelsea, MI
    One of my f12x's started missing a bit this season. A good 'italian tune up' improved it somewhat while new plugs were en route, but it would still miss at idle regularly. Replaced the plugs in both skis and they are purring like turbo-charged kittens again. The plugs were golden brown.
    They both had 32-33 hours on them. Just curious what kind of hours others are seeing out of their plugs before replacing...
    Thanks!
    Resident Guru CelticCrew's Avatar
    Frederick, MD
    Re: 33 hours on f12x spark plugs... good / bad?
    Iridium plugs foul easily in my opinion. They can last a long time if taken care of - sometimes up to 200 hours.
    I do not do quick starts with these plugs. I have had a few sets foul and I think it is do to quick starts (i.e. running it for 10 seconds or so). Some people will debate this but I've bought enough plugs to justify not doing this anymore. If I want to run it I run it on the hose for atleast 10 minutes so I'm guaranteed the plugs go through the enrichment cycle and do not foul.
    Another opinion I have is winterization techniques. I no longer put any oil in each cylinder during my winterization routine. Yes the manual says to do this but I think I foul plugs when I do this on the first start up the following season. This is probably debatable too but since I've had to change two sets of plugs at the beginning of the season on two different aquatrax models I will no longer do this anymore.
    My 2 cents...
    The List
    2005 Aquatrax F-12X (Macsboost Module, Torxracing IC, Custom Air Intake)
    2002 Aquatrax F-12X (Macsboost Module, Torxracing IC, 17/29 Solas, Plenum spacer, Custom Air Intake, Velocity Stack Insert)
    Jan 2007
    Illinois
    I agree im not putting oil in my cyl this year both of my skis were missing this year and new plugs seemed to fix it the other day before i changed the plugs i got a warning light and my ski went into limp mode it was either the spark plug miss or the hot water i was in im not sure but it was fine after about a min i still noticed a miss at idle hours later so i changed the plugs and it went away hopefully shes good to go now im at about 260 hrs second set of plugs now and on the non turbo 160 hrs plugs just changed
    Sent from my DROID RAZR using Tapatalk 2
    I dream skis jlfx car audio's Avatar
    Feb 2011
    jackson tn
    Put a set of plugs in my modded ski at about 65 hers now I'm at 130hrs on same plugs need to pull them and inspect but I have just been enjoying it way too much .
    05 R12x 142hrs w/ ic upgrade,strait pipe ,stock prop and boost 6380rpm @66.2mph
    09 F15x 39hrs .
    PWCToday Guru abmobil's Avatar
    Atlanta
    My current plugs have about 220 hours on them ,and its running fine. I will change them again after I drop it off at the dealer this winter for a valve adjustment cause they will def foul when they run it for the short period on the trailer.
    After the first year of owning the ski I always did a quick test start on the trailer before going to the lake. That is when it started fouling them. Now I wont start it ,but I will tap the start button to make sure it will turn over before leaving.
    Doing those quick test starts can foul new plugs in 20 hours or less depending on how frequently it is done.
    I also ride at least once a month in the winter so I don't bother with adding oil to the cyls.
    2006 Honda R12X----600+ hours
    Macsboost Module/ Torque Solution Intercooler
    2014 Sea-Doo RXP-X
    Stock
    Jan 2007
    southern california
    The resistors fail in the plug. Easy fix. The tool kit under the seat changes the plugs. That's the only repair these ever seem to need. So they gave you the tools.
    Bob
    02 f-12x gone but missed
    03 gtx sc sold went to Australia
    08 f-15x stock
    08 f-15x macboost stg 2
    FE 3D galcoated trailer
    Jan 2007
    Illinois
    Have you ever changed the plugs wit the tools under the seat ya it sucks i carry a trailer tire change tool and a socket set in my truck just in case you never know
    Jan 2007
    southern california
    Quote Originally Posted by sonic77 View Post
    Sure it sucks. Did I use those tools? No. I build KTM dirt bike engines and used my pro tools and torque wrench and xtensions and magnets instead. BUT in the middle of lake Powell for example next month they WILL work. Not even bringing a tool box other than a spare set of plugs.
    08 f-15x stock
    I dream skis xdrian's Avatar
    Mar 2006
    Brisbane Australia
    Service manual say change @200 hrs plugs got that out of mine.
    If they last that long change them then you know you have a good set for trouble shotting in the future
    Regards Xdrian
