650 Wave Jammer Engine Swap and novice Freeride/ Freestyle ski - Page 2
Page 2 of 31 FirstFirst 123412 ... LastLast
Results 11 to 20 of 308
    Resident Guru rock_smasher's Avatar
    Jun 2009
    PW, CO
    Re: 650 Wave Jammer Engine Swap and novice Freeride/ Freestyle ski
    I gotta see this... 1 of those builds thats so wierd its cool-ish? lol
    props to you for being different
    Those who will beat their swords into plows, will plow for those who do not.
    I got 99 sockets but a 10mm aint one
    charlotte,nc
    hahaha thats awesome! see if you can find a b pipe or something to put on it as well... i bet they will be fun for jumping cruiser wakes one
    96 superjet- rockered, -4, wide tray, adjustable footholds, kv148 mag setback pump, skat 7/14 impeller, rrp adjustable pole, blowsion ovp steering, 62t/62t, ada head, zeel A02T cdi, dual 44s, boysen power reeds, TNT SS chamber
    93-x2, newmiller ported SP750, milled head, R&D single 46 intake, sbn46, fpp blaster chamber pipe, hooker 9/15, umi, rhaas squirrel cage, dakine foot straps
    Chicago / Portage, MI
    Haha thanks guys. Yea eventually I really want to do a big bore/ ported cylinder on this. I remember hearing somewhere that Group K for some reason spent a decent amount of time working on the LX, so I think I'm going to call Harry and see what he recommends. That will be phase 2, which will be for next season. The 650 in theory with a little work should be equal to a good 701.
    Phase 1:
    stock engine with stock pipe
    Superjet 650 head
    Superjet stock carb settings
    16/19 ish impeller
    750 gph auto bilge pump
    stock ebox
    midshaft swap (650 coupler is different)
    intake grate mod
    pump rebuild
    Engine has been removed. We were going to run it memorial weekend but it somehow had a spontaneous exhaust leak. It ran fine last season. Good reason to pull the 500 and do a swap.
    32 measily hp.
    Oh also notice my ghetto fabbed flame arrestor. Another good thing about the jammer is its darn near indestructable. Even with just the screen zip tied in place, we ran the ski hard, sometimes with even up to 100lbs or so of water in it. On both my friends jammer and my own we've run them at darn near full throttle forward, sideways, and backwards continuously.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    Ok it has been a while since I posted. The Jammer is at my brother's house in Michigan so that limits my time working on it. I'll be able to devote some this weekend and next.
    I have taken a bunch of time to clean and prep the engine. Carb is jetted correctly near as I can tell, for a 650sj. 120 pilot 115 main. The LX had a 115 115, mostly I would assume due to the lower compression head. I've also heard that the LX had a different ebox which reduced revs, I'll investigate that further later on.
    Took this time to order all sorts of parts:
    17/20 impeller for WJ/WR 650
    650 SJ head
    650 gasket kit
    pump rebuild kit
    orange fuel and primer line
    750gph auto bilge pump with switch
    some other stuff which isn't really important
    I'm now slowly working on developing graphics for skis. Here's a sneak peak of my inspiration for this build, a Blowsion LWDE ski.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Resident Guru VXSXH20's Avatar
    Jul 2006
    Mid-Atlantic
    Looks Good, I believe ODD DUCK built a jammer with a 701 and a fx1 pump in it, here on pwctoday, It was dysfunctionally cool, I cant wait to see what you do with this,( No thread jack intended ) Goodluck!
    Ha. Yea her thread was one of my inspirations, so no harm posting that!
    Do you have info somewhere about her using a fx1 pump? I don't remember reading about that. I did ask her what impeller she was using. She was going to ask her husband I think and I never heard back.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Jul 2006
    Mid-Atlantic
    never actually spoke to them, I had read it somewhere along the lines. I will look again and see if I can find something, If I Do I will post it up here, Good luck
    PWCToday.com Is My Home Away From Home garrcass's Avatar
    Jun 2011
    Redding CA
    17
    Could you post the demensions of the jammer Hull area
    ( Girlfrends are cheap X2,s are expensive )
    Hull or pump? I actually have a pic with hull overall dimensions that I'm going to use for the graphics. Came straight from the repair manual.
    For those interested here is Group K's info. If they can make the LX get to almost 45 then a 100lb lighter ski with a few tweaks should be good for at least as much. And the thought of a 45mph Jammer makes me smile. Also impressive is the gains Group K lists for their sleeper mods- basically porting and cleaning up the existing parts. That really goes to show you how many losses there are on the 650. Group K goes on to say the Yamaha 650 engine has some of the most conservative port timing in the entire pwc industry... so porting yields huge gains.
    http://www.groupk.com/y633-701.htm
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    PWCToday.com Is My Home Away From Home 550/440's Avatar
    Jan 2009
    Arizona!!!
    The Jammer was a way fun intro ski - it would be awesome with more power!
    "needs carb work" is a classic excuse for I don't know wtf is wrong!
    2009 EME Q8, 1100 ADA WB1 with MRD. 2004 BLOWSION RN SJ.
    Big thanks to Newmiller Machine in Oregon for the great work! (Mcn6 on PWCtoday)
