Results 1 to 10 of 12
    PWCToday Guru Jetworx Hawaii's Avatar
    Dec 2002
    Lake Havasu City, AZ
    Sea Doo HX Magnum Pump queston
    Have a HX with Factory Pipe, FLame arrestores, Stock (rejetted) carbs. Wanting to try a 12 Vein Skat Pump (140mm). What would be a good pitch impeller to start with?
    Thanks to my all my 2017 sponsors:
    JETTRIBE www.jettribe.com
    JETTRIM www.jettrim.com
    HOT PRODUCTS www.hotproductsusa.com
    QUEEN RACING www.queenracing.com
    HAVASU FITNESS www.havasufitness.com
    McMURAY TV CENTER (https://www.facebook.com/pages/McMur...85229978177659)
    KLIPPER RACING
    CHUCK's SPEED SHOP
    PWCToday Guru HXLOCO's Avatar
    May 2007
    CHINO CA
    Re: Sea Doo HX Magnum Pump queston
    Hi Charles did you milled the head for more compresion? also are you using the stock nozzle or aftermarket I have a 16/21 and a 14/23 you can try so you dont have to buy one until you get the right pitch
    Sin City USA
    Come on Tony you don't need a Magnum pump, you are already on an HX for crying out loud
    lol see you at Lake Perris!
    Dec 2002
    Tony,
    Thanks, Its Bills Scott"s HX. We were thinking about doing some testimg with the magnum pump, and just wanted a starting point on the prop.
    KLIPPER RACING
    CHUCK's SPEED SHOP
    PWCToday Newbie wake_seeker's Avatar
    Aug 2011
    canada
    I was just wondering how to align a 96 HX MOTOR? I'm stumped.
    May 2007
    CHINO CA
    Quote Originally Posted by wake_seeker View Post
    you need an aligment tool from your sea-doo dealer otherwise you'll be burning rubber coupler every 5 minutes of use in 96's or newer
    May 2007
    CHINO CA
    Hey Charles: Remember 720's with factory pipe do not like to run at 6800-6900 rpms the back piston seize very fast at that rpm range 7250 7300 and up will compensate for the drag on left turn
    Top Dog Lakeside518's Avatar
    Jun 2007
    Clifton Park-Albany area, NY
    My HX turns 7150 usually. I have had my eyes open for a mag pump for it, no luck.
    PWCToday.com Is My Home Away From Home ko2's Avatar
    Ski Whoareville, NY.
    Quote Originally Posted by Lakeside518 View Post
    Race that beeitch in open next week bro !!!!!!
    Aug 2011
    canada
    Thanx for the reply HXLOCO, we used the tool to align the engine. Bolted the alignment plate on the back, slid the shaft in, set the alignment washer so the shaft slid into the engine. No shims needed, we could've put shims under the engine and set the alignment washer to match. The question is does the engine actually need shims if you're setting the center alignment washer? And if the alignment is that critical (we took out .016" shims) how can you guarantee that when you pull the engine out again to get the front drive shaft in that you aren't out by that .016"? Is the alignment tool mainly to get the alignment washer in line?
