Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    resident guru RivMan's Avatar
    May 2011
    Pinckney, MI
    Hold my beer and watch this...
    So this will be my build thread for my X2 build. Don't expect quick progress, or professional how-to's since this is my first shot at fiberglass work.
    Early this season I noticed my hull was completely split around the rear bond line, all the way across. I swapped my motor / pump into a spare hull I had, and decided this ski needed to be chopped up. It weighed noticeably more then my other hulls due to the amount of wet foam at the rear.
    Here's a breakdown of what I'd like to accomplish:
    10-12" chop
    Move pump ~7" forward
    Relocate steering 5" backwards
    Relocate Fuel tank behind engine
    Relocate Battery towards center of ski
    Flat Decked
    Rear exhaust, inline silencer
    Blaster Mod or NYNJA chamber
    The goal of all this is to basically empty the front of the ski, condense the center of mass, and build something that's totally different then any current build.
    I expect the ski to ride very nose high, be worthless in a straight line, and want to rotate while jumping (See where I'm going here?)
    Progress so far:
    Top deck chopped off, ski completely de-foamed, pump section chopped out
    More to come when I get a chance to work on it again!
    -Rob
    1995 Squarenose - 701 61x Blue/Jetmaniac ported motor, ADA Head, B-Pipe, BlackJack 44, X-Metal Pole, Hazard Bracket
    1992 X2 - Westcoast Head, Factory Pipe, SBN 44, Cut SXR Prop , JetTrim Seat / Dash Covers
    PWCToday.com Is My Home Away From Home srh967's Avatar
    Feb 2010
    pennsylvania
    Re: Hold my beer and watch this...
    Holy crap, You have gone mad!!!! Good luck with the build.
    Aug 2010
    Australia
    its going to take more than 1 beer you going to need a pub and barmaid for this build ... have fun..... chop chop
    modded X2 650
    Originally Posted by hyosung
    PWCToday.com Is My Home Away From Home iangdesign's Avatar
    May 2010
    T-town, AZ
    Flippie the X2 I am assuming...subscribed!
    You are not acting like the person Mr. Rogers knew you could be...
    701 SN SJ - Spider Square
    I dream skis SpaceCowboy's Avatar
    Jul 2011
    Belleville
    More pics
    Current build 93 x2 stock graphics
    Rad Dudes surf brace w/Ebox, Rad Dudes oil fill block off kit with primer hole, Rad Dudes aluminum engine cradle, Accusteer, fly bars, 750cc big pin bottom small pin top, ADA head, single SBN46, sxr prop 9/16, TBM pump stuffer, dual cooling mod, factory head pipe 650sx chamber, Westcoast exhaust mani, flow control valve, finger throttle, Rule 500 bilge, 1.5 chop, PJS waterbox
    Frequent Poster northidahoski's Avatar
    May 2011
    Coeur d' Alene, Idaho
    subscribed!
    Aug 2008
    CT
    Nice man!!! Get at that thing! Cant wait to see more pics!
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    May 2011
    Pinckney, MI
    I have gone mad, but what else was I going to do with a spare hull with a ton of wet foam! I've got cutting tools, and plenty of beer, so I've got that part covered.
    Time to start ordering some materials. I'd like to use West System Epoxy. Anyone have any recommendations on what to order? I've never done any fiberglass work, but I've got a pretty good idea on the process. I also need to get my hands on some shorter driveshafts. I think I want to tailor the pump location to a 650SX shaft, but I need to pick one up before I decide.
    Gonna be slow going, but it'll get done eventually.
    -Rob
    PWCToday.com Is My Home Away From Home WB1994's Avatar
    Jun 2005
    New Hampshire
    Pictures of X2's with sawsalls next to them give me goose bumps.
    Sep 2010
    syracuse NY
    Omg... I woulda bought that hull off you! Lol I have some weird obsession with it
    89 rockerd X2, ported and polished 65 SOLD
    93 waveblaster 701 SOLD
    Fix'd steer 650sx ​SOLD
    100% custom X2 project
    Originally Posted by JonnyX2
    One kick is maintenance....twice is abuse
