Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
    May 2002
    Blasterville, USA
    Brad Davis' 1100 SJ - kawi
    For all of the people who have asked me about it, here are some pics of Brad's kawi 1100 08 SJ. I will go on record as saying it is the most fun lake stand up I have ever ridden. The Kawi motor rocks if you know how to set it up and the SJ is so much more playful than the SXR. I love riding this thing.
    Thanks to Casey from IPD for hooking us up with some awesome graphics. Took me a while, but I finally got it all done this evening.
    Scottie
    Proud Member of TEAM TFP!
    JAM Racing
    Judge Motorsports
    www.hotproductsusa.com
    www.optimaracing.com
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ProWatercraftracing.com
    www.ipdjetskigraphics.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    I dream skis IPD Graphics, Inc.'s Avatar
    Dec 2007
    Cardiff by the Sea, CA 92007
    Re: Brad Davis' 1100 SJ - kawi
    Looks really good man....I bet that thing IS fun to ride!
    IPD Graphics, Inc.
    Top Dog jc21508's Avatar
    Mar 2007
    new york
    wow that ski looks sick!
    www.raddudesfi.com
    2008 Seadoo Wake 215 68.2 gpsed stocker
    2009 Kawi Sxr Tbm 3.5 degree bars, Worx sponsons, Pump Seal kit TBM intake grate TBM front sponsons, TBM throttle
    2007 Hydrospace stock class ready
    2007 hydro 1100
    2006 hydrospace stock class ready
    The twin
    PWCToday Guru syracuse's Avatar
    Jun 2007
    upstate ny
    awseome!!!!!!
    2004 SX-R 800
    2004 SX-R 1100
    1996 750SXI
    1994 750SX
    Oct 2009
    Jersey Shore
    Why must you constantly tease me with these 1100 conversions?!
    Now I'm wanting a SJ! Awesome build Brad.
    Aug 2008
    CT
    You used a Rad Dudes plate but what couplers and midshaft did you use?
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    PWCToday Guru skyline99k's Avatar
    May 2008
    Long Island, New York
    wow looks awesome!!
    2008 Seadoo Wake 68.2 MPH
    2009 kawasaki SXR Black 49.3 MPH, Mods TBM Front Sponsons, TBM Rear Sponsons, TBM Bars 3.5 Degrees, 80 mm Nozzle, 13/22 Solas Prop, Billet RRP Pole
    2007 Hydrospace S4, Stock Class Legal
    Top Dog iceracer's Avatar
    May 2006
    wi
    Nice job ...looks like fun...did you install solas mag pump stator
    PAIN IS AN EMOTION.....CONTROL YOUR EMOTIONS!!!!!!
    Top Dog customride0105's Avatar
    Nov 2008
    sterling va
    Thank you guys....
    Little run down of the ski..
    To come
    At least when my string hangs out I still ride...
    brad
    Nov 2008
    sterling va
    Ski started out as a 08 sj hull...
    Hull mods include...
    Tubbie destroyers.
    Tray widened 7 inches.
    Painted stright black.
    RPot carbon fiber hood.
    Motor set up
    Brand new kawi 1100 crank true welded
    New Cases ported cylinder ported by pat Sanford
    New Rpm head 150 compression
    New V2 reeds reed spacers
    Rd true 1100 intake mani
    3 new sbn 46s
    3 new taus
    Exhaust mod by J.A.M.
    New rd advance plate
    Rad dudes bed plate
    Kawi 1100 couplers
    ATP gutted water box
    Pump
    New 144 solas mag pump
    New solas stainless steel wear ring
    New hooker
    Pro tec down trim
    Pro tec ride plate
    Worx 201 intake grate
    Pole
    Rrp pole
    ATP pole bracket and spring
    Rrp 50mm risers
    Rrp steering set up
    Now the fun part cramming it all into the hull... Sooo much fun il tell yeah what...
    Hull must be ground down in ft. For tank to fit chamber basically got a be cut and rewelded due to clearance on hull. Got a cut stock rear exhaust carb hits exhaust over there if u don't. Stock battery will not fit will hit carbs must mid batter tray. Gas tank must be dented in or it will not fit.
    It's a big puzzle. Anything that u want a do tanks in the way..remove the ebox pull tank motor then u can get to it it will not slip rite out. Rejecting is simple on mine I can remove the exhaust tube and get rite to the carbs. But that's basically the only simple thing on the ski...
    The ski is a blast to ride handles very well.. And like Scottie said it's a very play full ski...
    brad
