Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 70
    Dec 2002
    Sunny places.
    Re: Brad Davis' 1100 SJ - kawi
    Awesome build.
    What about power curve??? Lots of bottom end and top end??
    Gera
    For all of the people who have asked me about it, here are some pics of Brad's kawi 1100 08 SJ. I will go on record as saying it is the most fun lake stand up I have ever ridden. The Kawi motor rocks if you know how to set it up and the SJ is so much more playful than the SXR. I love riding this thing.
    Thanks to Casey from IPD for hooking us up with some awesome graphics. Took me a while, but I finally got it all done this evening.
    Scottie
    Super jets ONLY - never green....
    Too much to list.
    May 2002
    Blasterville, USA
    That thing has power everywhere.
    SM
    Proud Member of TEAM TFP!
    JAM Racing
    Judge Motorsports
    www.hotproductsusa.com
    www.optimaracing.com
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ProWatercraftracing.com
    www.ipdjetskigraphics.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    Top Dog customride0105's Avatar
    Nov 2008
    sterling va
    Rejetting tonite
    At least when my string hangs out I still ride...
    brad
    resident guru Leg Dragger64's Avatar
    Jul 2002
    NC
    Thinking about doing one of these . Just got another 09 SJ hull and a clean ZXI 1100 .
    Wondering if the centerbleed pipe will fit this setup ? Rad Dudes blaster midshaft ?
    SHRED til your DEAD
    Nov 2008
    sterling va
    Center bleed will work but u still havd to chop out alot of the chamber..witch i dont think any one else has done a sj1100 including rad dudes. So theres no messurments to go off of untill u bolt it down in the hull as i didnt take any messurments. And getting the exhaust off is a pain in the as$..
    Rad dudes blaster mid shaft will not work..
    Sj midshaft cut down works
    brad
    Jul 2002
    NC
    Got any pictures of the pipe cutting , welding ? How much you had to chop ? Also sounds like you had to cut the exhaust tube down some . How much did you shorten it ? Would be nice to see some more pictures .
    SHRED til your DEAD
    Aug 2008
    CT
    How much did you cut the mid shaft?
    Shold have been 1.25inch off the stick super jet. Right
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Nov 2008
    sterling va
    Yeah I should have taken some while I was messing around under the hood. But il get some pics. I know I went into the chamber about half inch.on the outside there is no water jacket. I finally got around to making a mid shaft cover tonite..the ebox mounted behind the motor is very close to the hood latch the 3 boltes for the latch are rite there so the eboxis about 1/8 of a inch under that. So a stock sj or kawi coupler cover will not work as theres about 1.25 inch of gap between motor and ebox. So I made a coupler. Cover outa fiber glass.
    Yes mark...1.25 don't matter what hull u put it in everyone is going to be a 1.25 raider b1 sj use the shaft that goes to that ski. Motor mounts don't move on them as they are all the same only thing diffent is mid shaft/driveshaft.
    brad
    Jul 2002
    NC
    Is this ski going to be at Colonial Beach next weekend ?
    Would like to get a look at it if it is .
    SHRED til your DEAD
    Nov 2008
    sterling va
    Yes sir it will be..
    brad
