    I dream skis Skiaholic's Avatar
    Mar 2011
    Desert
    1978 Js440 E-box in 1995 550sx
    My friends ski that is a 1995 550sx has a bad e-box and I was wondering if I can use the e-box out of my 1978 js440?
    One bad 1992 Superjet in the making
    -Pro Tec pipe
    -Solas prop
    I dream skis ecotrip's Avatar
    Sep 2009
    Ontario, Canada
    Re: 1978 Js440 E-box in 1995 550sx
    Yes this should work.
    PWCToday.com Is My Home Away From Home MrSki's Avatar
    Sep 2005
    AZ
    Theoretically it will work but kind of a pain. If it's the one I'm thinking, it's a bigger box with different internal components. I could be wrong. There are some differences in wire colors though too which could be confusing. What is wrong with the 550sx box? probably easier to change a bad component.
    1992 550 SX - R&R port Kawi Reed, Kind of fast.
    1989 JS 550 - PJS motor Dual 46's, 50 MPH on GPS.
    1986 JS 550 - Engine build under way!
    1976 JS 400 - Pretty much just a shell.
    Mar 2011
    Desert
    I havent checked the inside of the box yet but It's not getting spark and we replaced the stator already. And last night when I plugged my 440 e-box in there was still no spark. Anyone have ideas of what this can be? I ran the volt meter across the stator and all tests came up good.
    -Pro Tec pipe
    -Solas prop
    PWCToday.com Is My Home Away From Home PrickofMisery's Avatar
    Ventura County SoCal
    Is the stop switch in a N/C state?
