msx 110 engine light
    Feb 2010
    North Carolina
    I have purchased a 2004 msx 110. It runs fine, but everytime I start it, the engine light flashes about eight times then goes out. It stays out until you start it again. Is this normal?
    PWCToday.com Is My Home Away From Home delagem's Avatar
    Nov 2004
    Homer, NY
    Re: msx 110 engine light
    Nothing to worry about. If there is a problem, it will continue to flash while the word is displayed indicating the fault, and will likely limit the speed.
    I sent you a PM with the best place to get a service manual.
    Very important with that machine to not overfill the oil, there are 3 lines on the dipstick, top is overfilled, middle is max fill level, bottom is low.
    Join Greenhulk.net, the best Polaris guys moved over there years ago...
    Micheal
    '58 Vincent Amanda Water Scooter, 0rpm, 0mph
    '84 SurfJet 236ss Freestyle, 5950rpm, 24.6 mph
    '91 Jetmate! SX-R 800,GroupK carbs,R&D 26cc head,R&D ProLok F/A, Coffman Rocket Pipe,Impros 13-20,76mm nozzle: 6630rpm and 38.1mph GPS
    '92 SL650/750, dry pipe,extended pump,trim,HotSeat Waterbox: 6320rpm, 50.1 mph
    '00 SLX,Tau Ceti F/A's,NuJet prop: 6670rpm, 63.1 mph
    '03 Octane, Watcon 2318 CDI
    '04 MSX140,Impros stage 2 Powertune 14/23,WetWolf,6deg wedge: 6750rpm, 60.5 mph
    Feb 2010
    North Carolina
    Thanks Micheal! I will check out the other site too.
