    Feb 2010
    North Carolina
    msx 110 engine light
    I have purchased a 2004 msx 110. It runs fine, but everytime I start it, the engine light flashes about eight times then goes out. It stays out until you start it again. Is this normal?
    Nov 2004
    Homer, NY
    Re: msx 110 engine light
    Nothing to worry about. If there is a problem, it will continue to flash while the word is displayed indicating the fault, and will likely limit the speed.
    I sent you a PM with the best place to get a service manual.
    Very important with that machine to not overfill the oil, there are 3 lines on the dipstick, top is overfilled, middle is max fill level, bottom is low.
    Join Greenhulk.net, the best Polaris guys moved over there years ago...
    Micheal
    '03 Octane, Watcon 2318 CDI
    Feb 2010
    North Carolina
    Thanks Micheal! I will check out the other site too.
