    Frequent Poster JettyJetSki's Avatar
    Oct 2010
    Da Heights, MI
    Oil leaking out of Exhaust pipe???
    Soo after it took forever to start now I have Oil leaking out the exhaust and it was a pretty good amount too. What does that mean?
    Re: Oil leaking out of Exhaust pipe???
    It means your engine was flooded with excess fuel & washed the inside of the exhaust out & you got black oily chit running out your exhaust.
    Put it in the water & drive it,it will clear out.
    Oct 2010
    Da Heights, MI
    K thx worx
    Jun 2008
    Glendora California
    Also, it is possible that the oil seeped into the crankcases over the winter. That happens when the crank seals get worn out.
    Bill O'Neal
    www.watercraftmagic.net
    For repairs and/or parts and appointments only:
    626 914 9509 M-F 10 am to 5 pm PST, ask for Chris.
    Always speak your mind because those who mind don't matter and those who matter don't mind.
    Oct 2010
    Da Heights, MI
    Ok well im still having trouble starting this thing. I tried to start it today and no luck whatsoever. I've tried pouring a lil gas into the cyl and still no go. Is there an easy way to pin point whether its gas or spark related? I would think its gas related because obviously its started up for me plenty of times within the last week.
    Edit: Sry wrong thread but if you do read this, its the same ski having this problem.
    I think your motor is flodding with fuel due to leaking needle & seats in the carbs.
    Jun 2008
    Glendora California
    The fact that putting fuel directly into the sparkplug hole is not compensating for a carbureation/fuel delivery problem, I'm with Dan on this. Gasoline fouled sparkplugs. Remove the 'plugs, spray with brake cleaner to clean and dry them, try again over and over until it will start. Once started hold higher rpm until the excess fuel is burnt off.
    If you continue to experence this problem, remove, rebuild and install new needle valves in the carbs.
    Bill O'Neal
