local machine work?
    PWCToday Guru moogiestix's Avatar
    May 2009
    Mt Clemens, MI
    local machine work?
    i keep blowing head gaskets in my 650... i put a straight edge across it last year and came to the conclusion it was not flat... im looking to get it milled...just a little bit... any place local and cheap that u guys trust? its a mariner head, and i have a fat head gasket for it after its milled... just dont want to ship it across the country for 10 minutes of mill work!
    1988 Kawasaki 440 js, - very mint, a little upgraded
    1987 Kawasaki 650 sx - So Clean
    No more sit downs in my garage... i prefer standing for now
    Lake St Clair everyday.....
    I dream skis bigredZ's Avatar
    May 2010
    Goodrich MI
    Re: local machine work?
    AAA grinding in troy can true it up for you more than likely. If your just going for a flat surface that may be your best bet to remove .010 or less.
    “Life is not a journey to the grave with intentions of arriving safely in a well-preserved body, but rather to skid in sidways, body thoroughly used up, totally worn out and loudly screaming ... Holy $h*t! What a ride!
    PWCToday Guru sxi steve's Avatar
    Jun 2007
    Clinton Twp. MI
    Jet Crafts Powersports, New Baltimore.
    http://jetcraftsunlimited.com/
    1999 Kawasaki 750SXI Pro -Modified-
    1995 Sea Doo HX -Clean Machine-
    http://www.x-h2o.com/showthread.php?...i-Pro-Revealed
    http://www.youtube.com/watch?v=dyw8fEcHvMs <---*The Science of Brapology*
    http://www.youtube.com/watch?v=gCM5T8oYCvw <---*The Science of Brapology, Episode 2*
    SE MI
    CJ's head and hole in Waterford - 248 683-6344
    I've had him deck cylinders, bore and shave heads all with great results.
    PWCToday.com Is My Home Away From Home IceRocket1286's Avatar
    Nov 2003
    Detroit
    Jet Crafts in New Baltimore. Its close to you and Mike is a great guy. If he is too busy with the time of the season shoot me a PM and I can point you to another guy that is close by.
    Do it.
