Results 1 to 10 of 12
    Frequent Poster JettyJetSki's Avatar
    Oct 2010
    Da Heights, MI
    What is stock compression on a Stock WaveRaider 1100?
    Is a cold compression test at 100psi low? Seems low to me.
    Apr 2006
    Las Vegas
    Re: What is stock compression on a Stock WaveRaider 1100?
    Yea, thats low. 120ish is what you're looking for.
    resident guru
    May 2010
    Trumbull CT
    Yep, 100 is low..
    110 is about the lowest I would have peace of mind running, and only if they are all equal.
    "stock" out of the box new would be around 125.
    BOB Build!
    876 Big bore 61x stroker.
    Every bolt on possible !
    RRP pole
    -Part outs-
    Yamaha Superjet- Lots of RN and SN parts
    Kawi 750SXI and SX- TONS of parts
    Waveraider-
    Oct 2010
    Da Heights, MI
    Ok well it does have 197 hours on it. Does that make a difference?
    Apr 2006
    Las Vegas
    Is it just one cylinder or all of them? The reason I ask is because its easy to get a bad reading. If all cylinders are even, try another gauge.
    Oct 2010
    Da Heights, MI
    All cylinders are even, yes. Guess ill go out and get a new gauge to test out.
    PWCToday.com Is My Home Away From Home tfergusonracing's Avatar
    Nov 2005
    Right in the lumberyard, Danny...
    I agree that 120 is where you should be, but since all 3 are even, I wouldn't be concerned.
    It takes a big man to admit when he's wrong. I am not a big man.
    Oct 2010
    Da Heights, MI
    Im I going to loose low or top end speed with lower psi? Sorry for the newb questions, just not sure.
    Apr 2006
    Las Vegas
    Lower compression = lower power, so yea. It would probably be more noticable on the bottom, if you notice it at all.
    Oct 2010
    Da Heights, MI
    Ok thx, Also with doing a good compression test should all three spark plugs be out and throttle wide open or each spark individually?
    Btw what is your guys opinion on my 1100(Stock) vs the XP800(Stock)? Which is faster? Low End? Top Speed? What bolt on parts can I get that would get me better low end? I used to have a XP800 and loved jumping with it. Im assuming with the bigger/heavier hull that I proly wont be jumping any waves with the raider too much or at all??? Sorry I should just start a new thread for this.
