do u want ur stock sxr 1100 to run 63-64 mph? - Page 2
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 63
    PWCToday Guru Limitedski's Avatar
    Apr 2008
    Danville, Ca
    Re: do u want ur stock sxr 1100 to run 63-64 mph?
    Quote Originally Posted by bbigfish View Post
    John, u have the inside track from "the man".
    Scottie Mac has 1 build thread to search-- sxr 1100
    Super1 has the long build thread that has most of the info.
    Read them and take notes?? The info is in the threads!!!
    To dry out the pipe u must plug the mid pipe water fitting that is below the head pipe.
    Again, if u think 48 Novi's will be better with a gutted wbox and a little port work, and a larger pump--u will be going 58-60!!!
    Don't break the formula!!!!!
    MM
    Who are you referring to Mark. LOL.
    Frequent Poster ceebee187's Avatar
    May 2005
    gander, ks
    a stock pump was not tested in this package.
    Impros can do everything for u. Dave will know what to use. Good luck!
    MM
    Quote Originally Posted by Chris03HD View Post
    If Mark doesn't mind me chiming in on his thread, I will tell you my experience with the stock sxr pump on my sxr1100.
    With a skat swirl 16/21and 80/83 nozzle combo, I gps'd at 59.8mph @ 7,400rpm.
    Last ride of the season, switched to a solas df 16/24 and 82/85 nozzle combo, I gps'd at 61.5mph, in less then perfect gps'ing conditions.
    This was all without, bigger carbs, intake, reeds, mag pump, etc.
    Just basically a well tuned stock bore setup with added compression, air filters, timing jumper, and dried out pipe mods.
    Looking forward to this summer and experimenting/tweaking some more. If I see 62+ gps'd, I'll be extremely happy, for the minimal investment made.
    Wow! Thanks for all the great info! After all the reading, this thread cuts right to the core with a couple of the many possible outcomes a guy can have with an 1100 conversion.
    This thread is a huge help to me!!
    Resident Guru skidmark's Avatar
    Aug 2002
    wa. state
    This almost the same set up I ran in my pratice boat . I ran a stock head , with the same results . Fill it with pump gas and pin all day long all season long !!
    Kevin Redinger #152
    Oct 2009
    Jersey Shore
    Quote Originally Posted by skidmark View Post
    Amen.
    PWCToday.com Is My Home Away From Home bbigfish's Avatar
    Houston
    Quote Originally Posted by Limitedski View Post
    Bro, their are actually several people that had this issue!
    Chris, jetting specs for stock carbs would probably help someone. Those are great results for the investment!!!!
    What would really help would be a post with the dry pipe mod, water routing mod, and electrical jumper mod, carb specs for 44's, 46, stock carbs, all on one page!
    Keep thread short and sweet.
    MM
    Thanks to:
    My family &
    Friends
    Resident Guru Watrboy33's Avatar
    Jul 2007
    Idaho
    MM
    A thread listing all of the above would really help... I'm running the stock carbs and have no idea where to start.
    Thank you guys for helping everyone else out, when it comes to the "right" formula!
    Top Dog ihate5mphzone's Avatar
    Feb 2012
    where 2strokes is allowed
    MM
    +1 on this
    Great thread bbfish this would really help on my next project
    Franklin D. Roosevelt "It is common sense to take a method and try it. If it fails, admit frankly and try another. But above all,try something"
    Sep 2008
    City of Blasters
    Great thread. Nice to see it summarize and see all the results.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Aug 2002
    wa. state
    I ran 900 carbs and manifold with 900 stock jetting
    Kevin Redinger #152
    Resident Guru 800amsoil4u's Avatar
    Jun 2005
    Morgan Hill, CA
    This needs to be a sticky. Thanks for all the information.
    Save up to 25% by becoming an AMSOIL Preferred Customer
    Prices listed are Retail. E-mail or Call me for a price quote.
    http://www.TrySyntheticOil.com
    Kevin Stubaus AMSOIL Dealer for over 25 years
    TrySyntheticOil@Yahoo.com
    1-800-AMSOIL-4U (267-6454)
    Yamaha 2001 GP1200R W/RXPX Engine in it
    Polaris 785 Pro Super Stock
    2000 Polaris Pro 1200 Super Stock
    Kawi 550 Mod, Stroker Reed Motor
