Addictor 333 Mini Outboard Boat to Rotax 787 Jet Conversion *LIL WAKE** - Page 11
Page 11 of 134 FirstFirst ... 9101112132161111 ... LastLast
Results 101 to 110 of 1333
  1. #101
    Re: Addictor 333 Mini Outboard Boat to Rotax 787 Jet Conversion *LIL WAKE**
    Gorgeous work...true professional.
    1990 SJ Bronco - 787 with -13 hull and carbon fiber hood. http://www.pwctoday.com/showthread.php?t=417485
  2. #102
    PWCToday.com Is My Home Away From Home beerdart's Avatar
    May 2005
    CT
    Thanks for the progress pics its getting me motivated to do some work on the JM today.
  3. #103
    PWCToday.com Is My Home Away From Home MCrider's Avatar
    Sep 2009
    Jackson MI
    this thing is going to be sick!
    1990 fixed steer SN SJ with bolt ons
    http://www.pwctoday.com/f72/fixed-st...sj-341918.html
    Quote Originally Posted by monSTIer View Post
    Smaller waterbox or you can clearance the waterbox with a trusty old persuasion device.
  4. #104
    I dream skis lilwake's Avatar
    Feb 2012
    Minneapolis, MN
    Lamar, BeerDat & MCrider- Thanks a lot guys! Beerdart, did you get any work done today?
    We started today by trimming the extra fiberglass off the transom, and cut the pump exit hole in the transom back to shape.
    Then we got the ski section placed and cut the back corners off the bottom of the ski section.
    Scraped most of the rideplate adhesive away.
    Then we feathered the fiberglass edges of the ski section and bottom of the boat so they meet perfectly flush.
    Then sanded thru the gel coat to expose the glass to get a great bond.
    After we sanded everything down to the fiberglass and got a perfect mesh between the two pieces we set the ski section in place and prepped all surfaces with acetone.
    then we put a drill case on the front of the ski section and used a tow strap to ratchet it down just enough to put a light even pressure so it sat flat everywhere. Also in these pics you can see we cut strips of mat to the shape we needed. We cut three layers so we could have them ready to lay just as the previous layer tacked up.
    First layer down
    Two layers
    All three layers finished up.
    It was a LOOOOONG day today, but we made a TON of progress. I am hoping to get the interior fiberglassed as well as the gap between the transom and the pump shoe within the next couple days.
    1988 Addictor 333 powered by Seadoo 787cc Rotax (110hp)
  5. #105
    Jun 2011
    orange, ca
    Great work! Looking good
  6. #106
    Aug 2011
    Wichita KS
    Been following your Ideas, and build since you started.. Its really coming together nicely.
    How are you gonna go about filling the transom / pump area gap? thought about using a fleece, or some other faberic to stretch across, and glue on both sides of the gap to give a nice contour? and solid surface to glass ontop of?
  7. #107
    PWCToday.com Is My Home Away From Home vshockey10's Avatar
    Jan 2007
    Midwest
    Awesome work. I really like all the pictures in this build thread, keep em coming! I was wondering the same^^^
    THANK YOU pwctoday community for all of your friendly knowledge. I can't thank some of you enough. Hope to see you all on the water!
  8. #108
    Sep 2011
    Kelseyville
    sub'd.
  9. #109
    Sep 2007
    Utah
    You guys are doing an excellent job. I'm jealous of your industrious brother. Mine lives 7 minutes away and yet I see him maybe once a month. All of his free time is consumed by Xbox.
  10. #110
    Feb 2012
    Minneapolis, MN
    Quote Originally Posted by sixfifty View Post
    Thanks!!
    Sent from my DROID X2 using Tapatalk 2
