Stand Up Hand Truck?
Results 1 to 10 of 19
    PWCToday Regular skirunner2486's Avatar
    Aug 2011
    Menasha
    I recently moved into a new place and have the perfect basement for wrenching. Problem is, in order to get a ski (stand up) down there, I'd have to get it through some basement storm doors and around a pretty tight 90 degree turn after coming down the storm door stairs. Getting it down the stairs would be no problem, its the 90 degree corner I'm worried about. The only way I can envision this working is to get the ski pretty vertical to make it around the corner. Obviously this is pretty tough to do when just carrying the ski with a couple guys. I came up with the idea of using a sturdy, low profile hand truck with bunks mounted on the rails. Using this method (and some straps), I think I should be able to get it vertical enough to make the turn.
    Anyone ever attempt something like this? Thoughts?
    Feb 2011
    claiborne county
    Re: Stand Up Hand Truck?
    Put someone in front to catch it, strap it down an go for it
    PWCToday.com Is My Home Away From Home iangdesign's Avatar
    May 2010
    T-town, AZ
    Don't forget getting it back up the stairs and 90 degree turn as well. If you can support the weight though you should be fine. Also think about larger tires so it isn't so hard going up and down the steps.
    You are not acting like the person Mr. Rogers knew you could be...
    701 SN SJ - Spider Square
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    larger tires will make it easier and help with stability. if you have access to a welder extend the bottom plate a little(the one on the dolly that the boxes and etc sit on), then add your bunks and you could set the ride plate against that plate so it doesnt slide off
    - (project) 99 fixed steer super jet - 144 pump, 10/17 impeller, protec trim, R&D grate, 61x/61x 701, destroyer tubbies
    - 94 WB1, 760, superjet FP limited chamber
    - 00 24/7 carbon - solas 144 mag pump, raider trim, 9/15 impeller, jet dynamics grate, 61x/61x ported 718, FP limited chamber, KP pole, KP pole bracket
    - (project) 89 x2 - 650 pump with stuffer, 9/15 impeller, OP nozzles, 62t/61x TNT ported 753, single 46sbn, blowsion adapter, superjet FP mod chamber, ATP waterbox
    I dream skis Wheelz22's Avatar
    Sep 2006
    Jersey coast
    That's a good way to skin the cat....I'd like to see a photo of it in action once it's all fabbed up....
    Northern fleet:
    85 550 (Power by PoM)
    86 550
    Southern fleet:
    89 550 (half owner, nice loaner ski)
    89 650
    92 550
    82 550 & 91 650 (don't own either, but do all the wrenching)
    (prop, plate, grate, bars on everything...and other assorted mods on the whole shootin' match)
    Member: SCCA, ALMS, IMSA Tudor Sports Car Series
    May 2005
    Right here
    Just carry it.
    PWCToday.com Is My Home Away From Home 550/440's Avatar
    Jan 2009
    Arizona!!!
    It will wind up like the guy who built the GTO in his basement - they had to dig up the yard and tear down the foundation to get it out! Don't forget, the ski is 7' long, so it will be difficult to make the tight turn without it being nearly vertical. Tight squeeze. Best of luck getting it in there!
    "needs carb work" is a classic excuse for I don't know wtf is wrong!
    DASA powered 2009 EME Q8, 2001 XLT rescue boat, 1100 WB1 in the works.
    Big thanks to Newmiller Machine in Oregon for the great work! (Mcn6 on PWCtoday)
    Jan 2010
    Nor*Cal
    Tuff shed
    You just need to rent an appliance dolly and a furniture pad. Put the ski on there pump down with the pad wadded up to keep it from smacking the dolly foot, then strap er in. Piece of cake. And as a bonus the appliance dollys have small tracks to make climbing stairs a breeze. I delivered furniture for 7 years.
    PWCToday.com Is My Home Away From Home gto0209's Avatar
    Dec 2009
    madison wi
    pull the engine and carry it down.
    Charlie
    95 sc yami 760
    94 blaster 1100
    97 sj
    Looking for a complete coffmans sc pipe and waterbox, pm me if you have one
