Js550 spark problems
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    PWCToday Regular Jetski61's Avatar
    Feb 2012
    Illinois
    Unhappy Js550 spark problems
    Ok so this summer my js550 bogged down and quit sparking so i went on here and alot of people told me that the cdi is probably bad. So i replaced it and now im still getting no spark. what could be the problem?
    Feb 2012
    Illinois
    Re: Js550 spark problems
    please i need help, ive been beating my brains in about this since summer.
    Resident Guru xpmr5's Avatar
    Jul 2010
    Elwood, IL
    first, check your ground wires and their connections l for looseness or corrosion.
    if all good there, check into your stator and flywheel....
    Mar 2007
    Is Everything!
    OHM test the stator, its takes only seconds. Do not over look a shorted stop switch, or bad stopper module.
    Feb 2012
    Illinois
    how would i ohm test the stator? like step by step. Im not up to date on the whole stator concept.
    Feb 2012
    Illinois
    also how would i check for a bad stopper module or shortened stop switch?
    Mar 2007
    Is Everything!
    Do you have a Multimeter?
    Feb 2012
    Illinois
    yes
    Mar 2007
    Is Everything!
    what is the year?
    Jul 2010
    Elwood, IL
    check for continuity between the start / stop switch wires with each of the red and green buttons pressed and unpressed.
