Results 1 to 10 of 11
    PWCToday Regular WillyG's Avatar
    Oct 2011
    SE CT
    Break in Procedure
    Bill,
    How should I break in the new top end on my 787?
    96 SeaDoo GTX
    I dream skis HX RACER's Avatar
    Feb 2010
    PSL Florida
    Re: Break in Procedure
    Hold that sucker wide open!!! lol
    SE CT
    Got to agree.get it warm re torque. And let her rip. Break it in fast = go fast. In my own foolish opinion.
    R.I.P. Super Sic
    Jun 2008
    Glendora California
    What you want to do is ride it normally, but fluxuate your throttle position for the first hour or so. Do not be afraid to go up to max rpm for short bursts of time.
    The rings rely on the compression to expand them, and the sharp edges of the crosscut honing job will seat the rings. This happens better above 1/2 throttle when the clyinder pressures are higher and exerting more outward force on the top ring.
    The first time out, run it for an hour or so, let it cool completely until it is cold, then retorqure the clyinder bolts and/or the head bolts.
    Bill O'Neal
    www.watercraftmagic.net
    For repairs and/or parts and appointments only:
    626 914 9509 M-F 10 am to 5 pm PST, ask for Chris.
    Always speak your mind because those who mind don't matter and those who matter don't mind.
    Oct 2011
    SE CT
    Thanks Bill
    96 SeaDoo GTX
    Jun 2008
    Glendora California
    Do not go nuts adding "break-in oil ". Too much oil will delay the seating of the rings and then the clyinder walls and the rings glaze over and never seal as well as they should.
    Bill O'Neal
    Oct 2011
    SE CT
    Bill, will one tank of 50:1 plus the oil injection be too much oil?
    96 SeaDoo GTX
    Jun 2008
    Glendora California
    Yes.
    The oil injection will provide plenty of oil.
    Bill O'Neal
    Oct 2011
    SE CT
    I have replaced the oil injection hoses going from the pump to the rotary valve cover though and they have no oil in them, is there a way to bleed them without running the engine?
    96 SeaDoo GTX
    Jun 2008
    Glendora California
    Yes. Bleed the oil pump. Remove the sparkplugs. Hold the oil linkage wide open. Use the starter motor to fill the two small oil lines.
    Bill O'Neal
