Page 2 of 23 FirstFirst 123412 ... LastLast
Results 11 to 20 of 224
    PWCToday.com Is My Home Away From Home SBrider's Avatar
    Nov 2009
    santa barbara/redding
    Re: Yamabooeey's 1200 B1
    what motor mounts are you using?
    I dream skis NorCalGSX's Avatar
    Jan 2008
    Sac-a-tomato
    Norm's original 1100 is the reason I am working on a Kawi 1100 Blaster. Once you ride one you will be hooked !!
    Also I had front row seat (3rd place) to see him lead a Polaris 785 by the nose at our last race in Nor Cal.
    Sep 2008
    City of Blasters
    Quote Originally Posted by SBrider View Post
    These are Kawi 440/550 mounts with a 3/8" 6061 aluminum. You will need to shim it up 1/16".
    Pics of holes I cut for electrical and plumbing.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Nov 2009
    what boat is the mid shaft from? this looks so easy, i cant wait to start my build, just need to fix my week spark problem with my motor.
    Sep 2008
    City of Blasters
    Yep, real easy. The hardest part was to hunt down the shorter mounts. Midshaft is from GP800 or GP1200. Mine is from a GP800.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Nov 2009
    im using a 98 xl1200 for the donor motor, you think mid shaft will work or should i use stock blaster midshaft?
    Sep 2008
    City of Blasters
    The GP 800 midshaft is shorter then the blaster midshaft. I have a stock blaster midshaft on my Yami 1100. I really like how it rides, but on this 1200 I wanted to move it back to see both side of the world. I also have a 155 pump in the 1100 and going with a 144 pump in the 1200.
    On your xl1200 midshaft, take off the triangular part and look inside the shaft. If you see splines 1" from your eyeball you can use it. Some midshafts have splines real deep and will not spline to your driveshaft because your driveshaft is not that long.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Sep 2008
    City of Blasters
    Also filled in the driveshaft area for better flow.. I use a 3/4" pvc glued in with polyurethane and filled with micro balloons/epoxy resin.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    resident guru
    San Jose, CA
    Alright Norm, Yammie 1100's, Yammie 1200's, GP927, 951, Kawi 1100....what next??
    Too many skis
    Will work for garage space...
    Apr 2006
    Las Vegas
    I'm taking notes here. So far this looks like the most cost effective way of doing the conversion.
