Upgraded drive shaft on my Tigershark 1000 daytona
Hey Guys,
I upgraded my driveshaft this summer to the new screw in style rather that the splined on both ends style. I did not change out the floating bearing and seals. Should I have? Is the new shaft smaller in diameter than the old style? My bilge pump was acting p this summer and when it isn't running, it takes on water pretty fast. If it is the seals, I want to replace them this winter to get ready for the spring. I just want to make sure I get the correct setup. Thanks for any help you guys can give me.
Mark
97 Tigershark Daytona 1000
96 Yamaha Waveraider 700
Top Dog
Re: Upgraded drive shaft on my Tigershark 1000 daytona
 Originally Posted by mspencer
Hey Guys,
Mark
I don't have the lead on the cheap seals but IIRC they were like 92-95 Sea Doospx or XP seals.
I usually just order them on ebay or country cat.
PWCToday's first Tigershark owner
ModeratorPWCToday.com Is My Home Away From Home
what does the bearing look like in the floating bearing assembly anyway? I've never looked at one. Is it a standard ball bearing bearing? The doo bearings are roller bearings and my xp had one and it was trash. I want to replace the one on my 1100 and i think i'm going stock if i can find one.
My quote for the week of 03-February-2013 to 09-February-2013: "time to hang up the skates"
Region 6 racing info:
Monster Energy Midwest Watercross Tour
Do you have it made in America?
Region 6
Novice Runabout N/A Stock
Shark Bait
#713
1999 Tigershark 1100R (ret.)
Novice 1200 Stock
1996 XP 800
Novice 800 Limited
2009 Novi-Tec carbs
Factory Pipe spec II
Skat pump/prop
MSD ignition enhancer & water injection
R&D drop nozzle
ADA head w/39cc domes
...and more.
Top Dog
It;s not a traditional bearing as much as it's more like a main or rod bearing on a car.
It's a coated copped bushing to me not a bearing.I just got the kit from country cat was like a $150 for housing seals, new driveshaft, bearing, and a few other tid bits.
really? Interesting. Now I'm not sure which route to take! You don't happen to have any pics of the kit, do you?
Region 6
Shark Bait
#713
Novice 1200 Stock
1996 XP 800
Novice 800 Limited
2009 Novi-Tec carbs
Skat pump/prop
R&D drop nozzle
...and more.
Top Dog
You kidding it was June of 2010 and my only ski was down! I had it done in 2 hours max lol.
ahh my bad. I thought you were in the process of replacing it now!
Region 6
Shark Bait
#713
Novice 1200 Stock
1996 XP 800
Novice 800 Limited
2009 Novi-Tec carbs
Skat pump/prop
R&D drop nozzle
...and more.
When I removed the engine from mine and checked out the floating bearing/seal found that even though I thought I had been getting grease to it ,it was nearly dry !! The only lube was water from the leaking seals .will be putting a bigger fitting on to ensure grease gets in
Dave
Tiger shark 99 TS1100R ,WSM crank kit ,Wiseco forged Pistons
2003 Yamaha GP1200R
65 Tbird
One very understanding wife (I Hope!) She started it!!!
I MUST BE MAD
- You may not post replies
- You may not edit your posts
Forum Rules
