My Sport Open Spec SeaDoo HX-1100 Build
Page 1 of 31 12311 ... LastLast
Results 1 to 10 of 307
    Oct 2009
    Jersey Shore
    Build is almost complete, so I figured now would be a good time to show the progress up until this point.
    With trying to keep the weight balanced in this hull, I have been weighing every part and relocating them (i.e. battery and ebox) where possible.
    Thankfully, I have a buddy that can turn my exact templates into metal and can tig weld with the best of 'em.
    Here's some highlights:
    - 951 xpl front drive shaft; cut, tapered, shortened, pinned and balanced.
    - Kawasaki 650 bed plate; modified, tig welded, gusseted, media blasted and painted.
    - Aluminum Ebox bracket; mounts stock box on carb side, tig welded and turfed.
    - Ebox simplifying; internal box cleanup, re-wiring, timing jump, and new battery cables.
    - Stainless exhaust outlet; right side of hull, tow hook incorporated.
    - Yamaha GP760 water box; cut, modified, tig'd back together and turfed.
    - Stock 1100 exhaust; dry out mods, stinger fitting added and lower out line relocated.
    - New bottom end; seals, crank, oring and collar.
    - Aluminum upsized (3/8") fuel pickup assembly.
    - Kawasaki 900 motor side coupler with SeaDoo 951 dampner.
    - Stator cooling plugged, oil injection blocked off and font bearing deleted.
    - New top end; pistons, gaskets, over bore, and cylinder media blasted and painted.
    - Pro Design head; 33cc domes new oring kit, and tapped for extra cooling.
    - Battery; relocated to rear with aluminum stringer glassed in and tapped.
    - Intake side; new CDKCV rack, R&D ProLite filter, 900 manifold, new reeds/stuffers/blocks and all gaskets.
    - Goki aftermarket (stronger) motor mounts.
    - Inside hull; front quarter inner hull removed, fiberglass reinforced center, inside prepped and cleaned and fresh epoxy coated.
    More to come soon.
    Oct 2009
    Jersey Shore
    Re: My Sport Open Spec SeaDoo HX-1100 Build
    Few more..
    May 2002
    Blasterville, USA
    That thing is going to be awesome Chris. Can't wait to hear how it runs.
    SM
    Proud Member of TEAM TFP!
    JAM Racing
    Judge Motorsports
    www.hotproductsusa.com
    www.optimaracing.com
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ProWatercraftracing.com
    www.ipdjetskigraphics.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    PWCToday.com Is My Home Away From Home cavemanX2650's Avatar
    Jun 2009
    Austin TX
    can you please tell me how you dry up the EX ?
    Looking good Chris !!
    PWCToday.com Is My Home Away From Home vshockey10's Avatar
    Jan 2007
    Midwest
    very nice!!
    Sep 2008
    City of Blasters
    Very clean nice work.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    PWCToday.com Is My Home Away From Home ko2's Avatar
    Ski Whoareville, NY.
    Wow - it looks great so far Chris. We are going to have to get together in the spring & run the yami 1100 B1, kiawi 1100 B1 & your 1100 HX ...!!!
    PWCToday.com Is My Home Away From Home nofear195's Avatar
    Feb 2007
    Newburgh, NY
    Quote Originally Posted by ko2 View Post
    you better hit the gym if you wanna hang on
    My Gopro videos
    ________PATCH MOTORS_________
    "Because Performance Is Everything"
    Custom parts have custom problems
    Banned rager31's Avatar
    Apr 2002
    ARIZONA
    Wow very nice HOLE SHOT World Finals 2012
    Mrs. Rager
