650sx fixted steer! - Page 2
Page 2 of 46 FirstFirst 123412 ... LastLast
Results 11 to 20 of 454
    Sep 2010
    syracuse NY
    Re: 650sx fixted steer!
    Well then... Lol yaa I've created about...3 I think so far... I just get carried away with power tools lol my thought process is just "well if I go too far I can just fix it!" lol I'm installing the scrupper tomorrow then fixing a hole in the pump cavity then re foaming.. For a hole about the size of a pistceo in the top of the pump, could I just put some 5200 in there then sand it or should I glass from the tray area then 5200 on the pump side?
    89 rockerd X2, ported and polished 65 SOLD
    93 waveblaster 701 SOLD
    Fix'd steer 650sx ​SOLD
    100% custom X2 project
    Originally Posted by JonnyX2
    One kick is maintenance....twice is abuse
    Banned
    Jul 2010
    Olympia
    You learn by expierence. cut away!
    Sep 2010
    syracuse NY
    well i told my shop teacher to not let me use the sawzawl for a few days haha so now im using air cutters so i dont go too far... i didnt want to cut the nose that much but the blade cought and pulled and went way up in haha
    Aug 2008
    CT
    Make sure you run 2 1/2 lines, 1 3/8s for water and add a extra 1/2 tube for a trim cable.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Sep 2010
    syracuse NY
    theres 3 stock lines but im not sure what diameter... o wow thanks, i would have completly forgot about adding a line for trim... my carbs came in yesterday, finished the motor, waiting on a high comp head. pipe mods done. foam and more resin to finish the X2 and then this is in the mail, should come together pretty quick after the X2 is done. doing that as a senior project that needs to be ready for presentaion in jan so once i finish the glass on that, this will take a little back burner
    PWCToday.com Is My Home Away From Home MCrider's Avatar
    Sep 2009
    Jackson MI
    you building a hood similar to wfos?
    1990 fixed steer SN SJ with bolt ons
    http://www.pwctoday.com/f72/fixed-st...sj-341918.html
    Quote Originally Posted by monSTIer View Post
    Smaller waterbox or you can clearance the waterbox with a trusty old persuasion device.
    Ok I know you said you chopped off five inches, my question is did you leave the rear set of rideplate mounts in the hull bottom, if you are counting the rub rail in the five inches you are probably ok, if you have cut past the rear set of rideplate mounts you have gone too far.
    PWCToday.com Is My Home Away From Home vshockey10's Avatar
    Jan 2007
    Midwest
    if you think you cut to much off you can always use a longer rideplate. Thats if you left the rear ride plate inserts like mentioned above
    What I did was a 2.5" cut measured from the back of the hull then angled it upwards to meet what I had already cut off of the rear bond rail. That comes in just behind the rear rideplate inserts.
    PWCToday.com Is My Home Away From Home WB1994's Avatar
    Jun 2005
    New Hampshire
    I think if you put the steering in the correct spot you wont porpus.
