650sx fixted steer!
Page 1 of 46 12311 ... LastLast
Results 1 to 10 of 454
    Sep 2010
    syracuse NY
    650sx fixted steer!
    the build youve all been waiting for! LOL
    i started it a while ago, stripped a hull for parts. got this hull for free and the parts hull for 20 bucks and a $25 gas card that im not sure how much more was on it lol the only pics are cell phone pics right now but ill bring my camera tomorrow... i got a little sawzall happy and cut pretty far in lol its past the last ride plate insert... i didnt put the pump and nozzel in before i cut so i cut it WAY too far but when i re foam it ill add some inches on it hahah heres what i got so far, i got a bunch of parts comming in the mail
    plans
    -blunt nose, and shortened
    -minus 5 inches in the rear
    -x2 trim
    -rebuilt motor
    -SBN 44
    -stock pipe mod
    -X2 steering
    -etc
    ill get more pic tomorrow guys!
    89 rockerd X2, ported and polished 65 SOLD
    93 waveblaster 701 SOLD
    Fix'd steer 650sx ​SOLD
    100% custom X2 project
    Originally Posted by JonnyX2
    One kick is maintenance....twice is abuse
    Sep 2010
    syracuse NY
    Re: 650sx fixted steer!
    o SICK the pics are big!
    Sep 2010
    syracuse NY
    putting another order into US composites, how much foam do you think is needed to fill in the tray area? i was thinking 8lb foam but they only have 1/2 cubic feet or like 10... is a lighter weighted foam ok to use too?
    You want to use the 4lb foam, two of the small kits should be enough
    Sep 2010
    syracuse NY
    sweet thanks
    Sep 2010
    syracuse NY
    i neeed oppinions, i stood on it and i think i may have cut too far... should i try to glass it back on and not take as much off? or just add some foam and ad 2-3 inches? realized it might porpus horribly with it so short... thoughts?
    PWCToday.com Is My Home Away From Home MCrider's Avatar
    Sep 2009
    Jackson MI
    Lol
    Sent from my evo using Tapatalk
    1990 fixed steer SN SJ with bolt ons
    http://www.pwctoday.com/f72/fixed-st...sj-341918.html
    Quote Originally Posted by monSTIer View Post
    Smaller waterbox or you can clearance the waterbox with a trusty old persuasion device.
    Quote Originally Posted by 315rider View Post
    Not really sure what to say here, yeah you might want to glass that back on and start over, jebbus give a guy a sawzall and he gos nuts !
    Sep 2010
    syracuse NY
    i just dont want to constantly be doing wheelies all the time and jump and land straight up... i think im just going to add a few inches when i foam. i got my scupper valve tonight. wish i cheched out prices before i cut my hole. i did a 2 inch cut (i think) i didnt really measure i just did as big as would fit, i did it different than running it down the side because i figured unless im turning or something all the water will get stuck in the ribs and i know water collects right where i cut it, i got 2 45* fittings so im going to shicane it a little and then just run it out the back normally. i could have done a 1 1/2 inch valve but it would have been more head aches. this valve was 20 and the 1 1/2 was only 10 bucks but the smaller one just seemed like it would leak...
    one question, i saw some "great stuff" foam and it said water resistant, can be sanded and painted... does this mean it would be closed cell? 3 bucks a can would be alot faster and cheaper than a bunch of 2 part foam...
    Awe man its Cavey all over again, I am going to throw some advice out here, take it or leave it. Put the tools down and start doing some reading, evrything you keep asking has been covered a zillion times, the way you are going about this is all wrong, ask questions then cut,foam, sand etc not vice versa, you are creating a lot of headaches for yourself if you continue the process in the fashion you are using now.
