Tips for winterizing your Aquatrax
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
    Top Dog
    May 2010
    Eastern North Carolina
    Winterizing your aquatrax is extremely important if stored for 4months or more, ethonal gas, and freezing conditions are concerns, and will cause problems on spring startup.
    Here are some steps that helped me through 5 winters.
    1. Remove battery and store indoors, 60 degrees or above is Ideal, trickle charge 1X a month.
    2. Antifreeze, If your conditions dip below 32, Cut a 6ft piece of hose, use a funnel and stand on back deck holding the funnel and hose at least 4ft off deck, and pour 2 gal of RV TYPE antifreeze till water is expelled through pisser, keep going till its "RED"
    3. Gas, Fill your tank and add "BLUE" STABIL, it the marine kind, this will prevent sweating and moisture in your fuel tank, and the Stabil will keep your fuel fresh for spring.
    4. Fogging, If you choose to do this, its wise to have a spare set of SPARK PLUGS, use a fogging oil and after fogging, install a "old, or used" set of plugs.......Keep a prestene set for use during the season.
    5. Oil change, its not required, but can be done at the END or Beginning of the season.
    6. Maint. joint, some over do this, every oil change you spray the maint. joint, in my oppinion its not needed on a winterization, unless a oil change was done, you fogged cylinders, now your adding CRC........all that oil will def foul a plug.
    7. Lube, all of your cables with CRC
    8. Wax, not required but is recommended if stored outdoors
    Top Dog
    May 2010
    Re: Tips for winterizing your Aquatrax
    Common problems that WILL HAPPEN if proper procedures are not followed.
    1. Cracked oil tanks, intercoolers due to freezing water left in cooling system, will leak water into hull or worse....inside engine
    2. Fouled plugs due to excessive fogging/Maint. joint lubing will cause ski to run bad or not start
    3. Fuel problems, expired fuel, moisture in tank and corosion due to ethonal fuels, also will degrade the pump sock, and cause ski to run bad in spring.
    4. frozen/stiff steering, trim, and reverse
    Following a proper procedure will have your Aquatrax out on the water QUICKER, and will not have you in the shop, or buying parts, or hunting down that water leak, or replacing the battery, or spark plugs, or having to suck out a full tank of bad fuel, or filling a empty tank that has moisture, and has coroded sock and fuel pump.
    if you have a turbo model, be sure to lube the wase gate & linkage.
    email watcon@watcon.com
    Please visit our web sites
    Jun 2009
    Sammamish, WA
    Thanks Joey! I appreciate the summary procedure with explanations.
    Top Dog
    May 2010
    Quote Originally Posted by mastermindpro View Post
    I have requested this to be a sticky for the winter months......I will start one in the spring....."How to wake up your Honda from its winter sleep"
    Hopefully everyone can comment what they do or don't do, what works and what dosen't also those guys using pumps with the antifreeze, also will save some troubles in the spring start up months.
    Frequent Poster StonedInNy's Avatar
    Jul 2009
    long island N.Y
    Also for you mac intercooler users there is a drain on the lower front part that you should drain prior to antifreeze.Thanks for the tips 1fatlazy
    Top Dog
    May 2010
    Someone needs to post up pics on a home made pump system.......That would be good for this thread.
    maryland
    Good post - I propose to augment a couple of items.
    The fuel tank need not be filled. There is virtually no air transfer via the vent. Vapor pressure of the fuel pretty much eliminates this as an issue. Therefore there is no condensation. It's a bit of an old wives tale, sort of like "never put your battery directly on a concrete floor" (also not an issue.) There is a good argument for leaving your fuel tank nearly empty though - that gives you a chance to fill with fresh fuel in the spring. Personally, my boats are left about half full and stabilized.
    Definitely change your oil at the end of the season. Used oil contains dissolved elements from the combustion process. They combine into all sort of nasty compounds over the winter including things like sulphuric acid!
    Top Dog
    Dec 2008
    Rock Hill, SC
    Quote Originally Posted by paxfish View Post
    You need to read up on your fuel recommendations. A PWC is not nearly as bad as a boat but leaving the fuel tank half full on a boat can cause bad problems. Read the extensive research by Boat U.S
    http://www.boatus.com/seaworthy/ethanolwinter.asp
    I am not trying to bash anyone but I want everyone to know what is best for their ski.
    2012 RXP-X 260
    2007 GTX LTD
    PWCToday Regular pseudonym's Avatar
    Jan 2006
    Maryland
    Quote Originally Posted by 1fatlazysofarider View Post
    Do you mean something like this?
