New Battery: Code P1513
    North Carolina
    Question New Battery: Code P1513
    I have a 2007 RXP Seadoo. My battery was week so I re-charged overnight. When I re-installed it. The motor would turn by not complete. I am now getting a Code P1513. Any ideas? Thanks!
    PWCToday.com Is My Home Away From Home Tom V's Avatar
    TarponSprings FL
    Re: New Battery: Code P1513
    could be the lake temp sensor is out of range or compass out of range, something like that, You would have to hook the ski up to a computer to find and clear the fault. The ski will run fine with the code posted on it.
    www.shopsbt.com
    The Worlds Largest PWC Engine Remanufacturer
    94 sl 750 (sold)
    99 slh 700 (sold)
    2000 pro 1200 (sold) old race ski
    2001 genesis
    96 superjet 701(sold)
    97 Hurricane
    97 sl 700 to 1200 conversion
    03 octane (sold)
    97 sltx 1050
    96 Hx limited class
    07 GTI se 155
    05 150 sportster 215
    98 PRO 785
    We can't solve problems by using the same kind of
    thinking we used when we created them.
    --Albert Einstein
    I believe 1513 is the lake temp sensor, it will read out of range if parked on asphalt or pavement on a hot day, ignore it it will go away once you dunk it in the lake. The way the system works is it reads every sensor before startup, if one is out of the normal range it throws up a code.
