a lot of you have seen this ski before i had it put all the way together, but I figured I'd post up some pics of it completed. I got this ski and another ski in a package deal with a bunch of parts a few weeks ago. The viper motor was sitting in a hull prepped for paint and this hull had a mildly modded 550(build will come this winter). I took both skis completely apart and then took the best of everything to go into this hull. I got new fuel and cooling lines and had to buy the PJS f/a and the Westcoast bulkhead brace. The cdi is overheating and makes it run bad after a few minutes, but I have another one that should work that I will install tomorrow. I plan to put in footholds this winter and ditch the lifter wedges, but I just want to ride it for now. The hydroturf is starting to come up in the back and needs to be re glued too. Here's the final list of mods:
Viper 7000
Dual keihen 38's
PJS f/a
Westcoast pipe(have head pipe for a pjs, will get the chamber for it this winter)
PJS exhaust manifold
Mariner waterbox
Jettrim front hull braces(more coming soon)
Goki motor mounts
Aluminum 440 driveshaft
Afterburner pump w/ 16* solas
Westcoast open intake grate
Ocean Pro finned rideplate
Ac Aluminum handlepole
650 Quick steer plate
4* bars
Dual 500gph rule bilge pumps w/ blowsion bar switch
trigger throttle
Pole spring
Converted to right side exhaust
Dual cooling
OCJS extended fuel tank
Westcoast stainless steel fuel pickups
Primer
Hydroturf w/ Lifter Wedges
Viper 7000
Dual keihen 38's
PJS f/a
Mariner waterbox
Goki motor mounts
4* bars
trigger throttle
Pole spring
Dual cooling
Primer
Comment
