Results 1 to 8 of 8
    PWCToday.com Is My Home Away From Home jetman624's Avatar
    Nov 2003
    South OC, CA
    Piston Recommendation
    Who do you guys like for pistons? Pro X, Wiseco, other, etc...
    Thanks!
    '02 SXi Pro: Factory Limited pipe, ported SXR cyl, SSP stearing system, WORX ride plate, skat trak intake grate, blowsion tubbie II, 3DR SS hull extensions, 3DR trued hull, 3DR pump shoe mod, bored pump nozzle
    '92 X2: Mostly stock, except for the 750
    '91 X2: #718
    Top Dog stu123carp's Avatar
    May 2011
    uk
    Wiseco for me all day.
    Fixed steer for life"ONLY HOMOS RIDE POLES"
    Dec 2004
    Richmond Va.
    Re: Piston Recommendation
    Stock Kawi, then Pro X and when you don't have a choice, Wiseco. You will get longer life out of a good cast piston (Kawi, Pro X) then you will out of a Wiseco. A good cast piston being hypereutectic (11% + ) silicone is harder, more resistant to thermal expansion and scuffing (seizing). It will run better longer. This is not to say a Wiseco is bad, its just not as good of a choice for most engines as a good cast piston. I know that every person out here who runs a Wiseco will chime in and tell you how great they but you asked.
    Top Dog phlipcyde's Avatar
    Jul 2006
    CT
    A couple engine builders I talked to said that wiseco pistons were great but needed an extra long warm up time compared to other brands. I guess they need to swell to fill up the cylinder more than others, and if not warmed properly will cause a slight knock from the piston rocking in the cylinder. I've ran stock kawi, pro x, and wiseco and never noticed any difference between any of them. Just putt around for five minutes before smashing the throttle and it'll be just fine
    ...Flatdecked, PFP'D, Stroked, DASA 970 X2...
    http://www.pwctoday.com/f100/flatdec...el-356987.html
    Oct 2009
    whittier, CA
    i use wiseco when i rebuild my motor, did 2 laps around the lake then after that full throttle on a 28mm carb and westcoast head at 180comp going on 2 summers now with no problem.
    86 x2 stock
    • fast
    • reliable
    • cheap
    you can only pick two!!!!
    Sin City USA
    OEM or Pro-X
    Aug 2008
    CT
    Quote Originally Posted by phlipcyde View Post
    And Wiseco takes a much much longer first breakin time.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    PWCToday.com Is My Home Away From Home stupid couchers's Avatar
    Aug 2010
    Romoland CA
    Where do you get oe ART pistons? Haven't been able to find any for my small pin.
    1991 800 X2 2013 WF #3
    1988 440 Michele "In A Hurry" Curry Superstock 440
    2004 SXR Lites
    Sponsored By:
    www.rivaracing.com
    Owner/Operator at www.c57racingproducts.com
    Authorized Dealer For Hot Products USA, DASA Racing, Rhaas Products, Skat-Trak USA, LVP, Bomber Eyewear, WSM Parts, and many more.
    Like Us on Facebook!
    www.facebook.com/c57racingproducts
