Results 1 to 10 of 11
    Frequent Poster Osprey999's Avatar
    Jun 2003
    Tampa, FL
    What color should the spark be on the NGK Iridium Spark plugs
    I'm getting an orange spark from my plugs when tested connected to the coil and touch the ground.
    Is this correct?
    Would a wet fouled plug have an orange colored spark?
    I'm going to change the spark plugs first, but didn't want to waste the money if there is something wrong with the CDI or something.
    2007 Toyota Rav4 Sport
    2008 Toyota Tundra 5.7L 4x4
    2005 Honda F-12X GPScape
    2005 Honda 13.0hp Pressure Washer
    2006 Vento Phantom 150cc
    Re: What color should the spark be on the NGK Iridium Spark plugs
    Purple with green polka dots.
    Top Dog
    May 2010
    Eastern North Carolina
    Quote Originally Posted by Osprey999 View Post
    Is this correct?
    Blue is best....orange may need some plugs, The CDI is built into the ECU
    Jun 2003
    JACKSONVILLE FL.
    Joe,
    I was not impressed with the spark intensity of the Honda ECU. Even with new plugs the spark looks a little weak and is not a strong blue like you would expect.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
    Jun 2003
    Tampa, FL
    Quote Originally Posted by JR IN JAX View Post
    Joe,
    Even with new spark plugs, what color would you get? Could the coils be the reason for weak spark?
    Spark is spark.
    Jun 2003
    JACKSONVILLE FL.
    I hate to disagree but a weak yellow spark is not very good and in most ignition systems means trouble. A bright blue is your most desireable and is usually a sign of a healthy ignition system. The hottest is an ultraviolet that you can not even see except the blue/maroon color.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
    SE CT
    Is there an issue with the ski? Have you retried with new plugs?
    Jun 2003
    Tampa, FL
    Quote Originally Posted by AC 46 View Post
    I just ordered new plugs so I'll let you know how that works.
    I'm not sure why I didn't think to get new plugs to begin with, after having a cracked exhaust manifold which allowed salt water into the head/valves and cylinders
    Like I said earlier, it ran fine for a little while on the hose, and then just quick. Trying to start it back up wet fouled the plugs.
    Two more oil changes, and new spark plugs and I should be home free.
