Results 1 to 6 of 6
    Mar 2005
    tacoma, washington
    Throttle body problem on F15X
    My Throttle body went bad on my F15X last week. The shop I go to said they had another F15X come in last week with the same problem. My shop tells me Honda has them on "back order".
    Any one else having problems with the Throttle body on the F15X? Is there solutions or preventions?
    soundrider
    I dream skis jlfx car audio's Avatar
    Feb 2011
    jackson tn
    Re: Throttle body problem on F15X
    What kind of problem?
    04 Honda R12x modded with large IC,, large plentom, strait pipe , turbosmart fcd2, turbosmart mbc, wideband o2 gauge, vcs2 methanol injection, 14/31 prop (gps 68.2 )
    05 R12x w/ ic upgrade,strait pipe ,stock prop and boost 5380rpm @66.2mph
    Top Dog
    May 2010
    Eastern North Carolina
    What went bad on the throttle body? was it the throttle position sensor?
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    If it is the TPS even though they say it can't be replaced, it can if it's anything like the F12. You can use a dremal to cut a slot in the head of the studs holding it on and they will unscrew with a screwdriver. Not a very common problem but Honda uses the same one on some of their cars.
    03 Honda F12X (my favorite) Red of course
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X, 05 SeaDoo GTX Supercharged
    Need to have:
    F15X
    Top Dog
    Dec 2008
    Rock Hill, SC
    One of my buddies was told his R12x needed a new throttle Body (along with a bunch of other sensors) by the dealership but turns out I ended working on it and all he needed was a new ECU. It is still running great. Also had another buddy just by a 2004 R12x for 3k in great shape.
    2012 RXP-X 260
    2007 GTX LTD
    I dream skis Quinton Robbins's Avatar
    May 2010
    JONESBORO ARKANSAS
    I was told by the owner of Xtreme Honda in Brandon Florida that the ONLY issue they have seen on the 15's has been with the throttle body. He said that they have seen a couple have a seal fail inn some that cause some leakage.
    I see a Ultra 300x in my future.
