Yamaha Super Jet Auto Drop/ Manual Trim Nozzle System
    Apr 2003
    Calimesa, California
    Introducing from Skat-Trak the highly anticipated Auto Drop/Manual Trim Nozzle System for the Yamaha Super Jet. Unlike its Kawasaki 800 SXR predecessor, this drop nozzle system allows you automatically drop the steering nozzle while turning or to drop the steering nozzle with a manually operated, handle bar mounted lever.
    This drop nozzle system is compatible with both the OEM Yamaha Super Jet 144mm or the Skat-Trak Yamaha Super Jet 140mm Magnum Pump. The kit includes a Venturi nozzle with the capabilities of being machined between 80mm to 86mm exit diameter sizes, a variable trim ring, a lengthened Steering nozzle with the capabilities of being machine between 82mm to 89mm exit diameter sizes, a manual trim cable, and all the accessories for mounting. Specify nozzle sizes and pump size when ordering. (UMI Lever sold separately)
    Part # PRNYAMSJ
    Yamaha Super Jet Nozzle Kit- without siphon, Manual Trim/Auto Drop w/hardware and cable
    Part # PRNYAMSJWS
    Yamaha Super Jet Nozzle Kit- with siphon, Manual Trim/Auto Drop w/hardware and cable
    Retail $595.00
    Part # PRNLEVER
    UMI Cable Lever
    Retail $82.70
    If you are interested in placing an order, please call 800-969-7528 or e-mail sales@skat-trak.com. If you have any further questions, please call (909) 795-2505 or e-mail tech@skat-trak.com.
    PWCToday.com Is My Home Away From Home SUPERJET-113's Avatar
    Nov 2001
    Havabrew, Havascrew, Havasu!!
    Re: Yamaha Super Jet Auto Drop/ Manual Trim Nozzle System
    Pics?
    I MAKE EVERY GASKET FOR EVERY 2 STROKE YAMAHA, KAWASAKI, AND SEADOO I CAN HELP! SHOP AND COMPARE!
    CHECK IT OUT: http://www.x-h2o.com/showthread.php?t=57730
    May 2008
    Clodumbus, oHIo
    bump
