97 XP VTS Fuse Keeps Blowing
Results 1 to 10 of 11
    PWCToday Newbie coolcam_6's Avatar
    Jun 2011
    Colorado Springs, CO
    The 7.5amp fuse up front for the VTS keeps blowing on my 1997 XP. I've done an examination of all the obvious wires/cords, replaced the motor, checked all other fuses, and it is still blowing that fuse instantly every time power runs to it. After staring at the tech manual for a few hours and reading all the VTS text which had nothing to say about this problem, I'm at a loss. I'm hoping someone out there has had a similar problem and can shed some light. I bought the new motor/module OEM from WCSS, so I'm assuming I can trust that its good. Any suggestions would be appreciated; I'd hate for that $230 motor to have been bought for no reason.
    PWCToday Guru woodsrider40's Avatar
    Jul 2010
    Clinton TN
    Re: 97 XP VTS Fuse Keeps Blowing
    The VTS box maybe bad that's causing the fuse to blow ( not the motor ) but the little box on top of the VTS housing.
    Mine went out so I just unpluged it & put the nozzle in the middle & ride.
    94 SPX
    96XP
    Jun 2011
    Awesome. You're the second person to say it could be the component on the housing, so I'm going to go with that. It's the only lead I have as of now, lol. I appreciate the advice.
    Jun 2011
    California
    I have the same exact problem on a 2003 seadoo xp. i know nothing about how to work on it so its been to the shop twice in the last week. they put in a new motor and a new vts case, so i came out to the lake(1 1/2 away from shop) and the vts doesn't work...took it back and had them replace the switch and the fuse. I came back up to the lake and plan to stay for a week and a half, took it out and within 10mins it got stuck in the top position. any suggestions? i need maximum detail in your response because i don't know what im looking at. i was thinking that i would just get a new fuse put the vts in the middle and wait for the fuse to blow and deal with it later? if i did that, where do i find the fuse and what type of fuse? I know its in the MPEM or something module but i don't know where thats located.
    May 2008
    florida
    PWCToday Newbie visionoutfitters's Avatar
    Aug 2018
    Arizona
    Did you ever figure out what it was? Mine is doing the same thing even leaving the 6 pin vts harness unplugged it will still pop as soon as I put a fuse in.
    May 2017
    New Holland
    Go to the link below then look at the VTS Info and Repair section. There is a lot of great information in the FAQs section.
    http://www.pwctoday.com/showthread.php?t=236205
    Aug 2018
    Arizona
    Yes but it says nothing about my issue.
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Something is going to ground if it kicks the fuse instantly, I'd check wires for ground that should have none, it'll show 0 or close ohms. Then I would open her up and see what's grounding out, if the board is corroded a lot it could be layers in the board shorting. I don't know if that is a multi layered board but it prob is. There is a good chance a visual inspection of the components can find a short
    Aug 2015
    Birmingham
    Rem that you can do this with out that vts gauge with the buttons, motor and a pwr window relay. "What about the stops?" Ok, a voltage sensing pwr window relay, it sees the spike when the window or in our case trim hits the end of it's range.
    VTS looks like it was designed at Polaris
