Results 1 to 9 of 9
    May 2006
    TN
    Substitute for Loctite 518 and Loctite 592
    I can't find two products I need to rebuild the pump on my 1996 XP. Loctite 518 Gasket Eliminator and Loctite 592 Pipe Sealant with Teflon.
    What is a readily available substitute at a local Autozone, Advance or Oreilly autoparts stores?
    518 is referred to on Page 217 of the shop manual for the seal housing and seat.
    592 is referred to on Page 220 of the shop manual "apply loctite 592 on threads of the fitting tool. I believe this only refers to pressurizing the pump to test for leaks, but if it is completely rebuilt, I should not have any leaks.
    I'm driving you guys crazy, but this is my first time having to work on a ski and I'm doing ok for a novice, but I just can't afford to screw anything up. I've already spent more than I planned on this ski and the wife is going to hang me if it doesn't get on the water soon.
    You've all been a big help, especially Mr. Bill. I wish I could just download his brain. Thanks for everything.
    resident guru smoofers's Avatar
    Jul 2006
    Granbury, TX
    Re: Substitute for Loctite 518 and Loctite 592
    Check and see if you have a Fastenal in your area. They regularly stock both.
    SAC Racing
    2010 R5 Water X Racing - Rider of the Year
    2011 R5 Water X Racing Beer Pong Tournament Co-Champion
    May 2006
    TN
    Is that a store or a brand? And what version of Fastenal if its a brand?
    Jul 2006
    Granbury, TX
    It is a store, they sell industrial supplies, hardware etc.
    http://www.fastenal.com
    SAC Racing
    Aug 2008
    Boise
    try a dealer if you want the exact stuff. I got some 517 (about the same as 518) from Tacoma Screw
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
    PWCToday.com Is My Home Away From Home seadoo_newby's Avatar
    Oct 2008
    Virginia
    You should be able to pick up the permatex brand of 518 and or 592 at Autozone or Advance Auto. The 518 is an anaerobic thread sealant used for the pump cone mating surfaces and the oring, where as the 592 is used for the pump cone plug, as it is a high temperature sealant. I believe the 592 comes in a white tube. I hope this helps.
    "RIDE IT LIKE YOU STOLE IT"
    God Bless The United States of America
    Jun 2011
    North Texas
    I read that Permatex bought Loctite out several years ago. We should have a cross reference for our old service manual directions to the new readily available Permatex number - especially the 242, 572, 592's.
    Aug 2008
    Indianapolis
    I quit using Loctite 518 for everything because it is ****, and Sea Doo knows that as well, as they quit using it too. For both of these applications, you can use a good sealer like Threebond 1211.
    Loctite 518 was used for a number of things on the old skis, like crankcase mating halves, and pump mounts. Problem is that it degrades over time and crumbles and you have leaks all over. The silicone-based sealants never go bad.
    Frequent Poster outlaw55's Avatar
    Jul 2010
    Kerrville, Texas
    The above posts are correct. Use Permatex, if you look they will have the same number. You can get them at any auto parts store.
