Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    PWCToday Regular dg99's Avatar
    Jul 2010
    Vancouver, BC
    DIY Floating Dock Ramp: Progress Thread
    A few months ago I stumbled upon this thread at x-h2o where someone built a floating dock ramp for his stand up (below):
    My dad has a slip at the local marina for his boat that opens into the slough and delta where I ride, so I decided to build something similar to keep my SXR down there over the summer. I picked up a bunch of 5 gallon jugs that the fire department was going to recycle and built a frame out of treated 2x8s to house them. On top, I've used 2x4s and decking plank for the bunks and some 2x6 for the ramp leading up to them. I had a friend weld a steel plate to a square rod to mount a winch on. The end of the ramp is going to be hinged to the existing dock, and we're going to build a deck across the corner of the existing dock to put a dock box on and hide the hinges from view. 15 jugs x 20 litres gives 300 kg's of float at full submersion, which is over 600 lbs, so if the SXR is 300 lbs and the frame is about 150 the barrels should be submerged about 3/4s of the way when the jet ski is loaded up. I'll update the thread with progress, today we picked up the lumber and built the frame, hopefully will be dropping it in the water tomorrow and bolting up the hinges.
    May 23rd:
    The ramp is going to sit along the dock in front of the boat:
    The 5 gallon jugs:
    Building the frame:
    Test fitting the ski on the bunks:
    -dg
    2004 SXR 800
    resident guru Mr Bojangles's Avatar
    Aug 2009
    Brevard County Florida
    Hey that was me! It's still there too right now. The only problem I ever had was it rocking side to side so if your mounts good to the dock or sea wall you should be good. Keep the pics coming
    1989 Kawasaki X2
    2005 Yamaha XLT1200
    2008 Water Craft Factory hull
    Truck Bed Launch System - http://www.pwctoday.com/f26/mr-bojan...ml#post2683099
    PWCToday.com Is My Home Away From Home cavemanX2650's Avatar
    Jun 2009
    Austin TX
    Re: DIY Floating Dock Ramp: Progress Thread
    man are them boats in hot chocolate or what ?!?!?! LOL
    and if you can find me a 300lb SXR ill buy 2 of em hahaha
    I dream skis the floor guy's Avatar
    Mar 2011
    Arlington Texas
    looks good so far keep pics coming. lol the lady in background dont look to happy your building it.
    "If at first u dont succeed, skydiving isnt for you!"
    "Never take life too seriously. Nobody gets out alive."
    "If u dont like my American Flag call.... 1-800-Get-F-Out"
    00 XP
    98 XP L
    98 GTX L & 98 GTX L "under construction"
    Jul 2010
    Vancouver, BC
    Quote Originally Posted by Mr Bojangles View Post
    Haha cool, good to hear it's still holding up Didn't you end up hooking an air line to the barrel to lift/lower the ramp? I figured it might be a bit tippy so I went with lots of small jugs and a wider frame, going to secure it to the dock with some heavy duty hinges and lag bolts to hopefully prevent swaying.
    Lol, the lady in the back is my mom shaking her head at us, thinking "what the hell crazy project are these two doing now"
    -dg
    2004 SXR 800
    Aug 2009
    yup, I did. I dont have any pics of it setup like that. but all I did is drill some holes in the bottom of the barrel, and run a valve to my pump for my airdock. It works pretty good and makes it a bit easier to load. I have to keep it all the way out of the water since its in salt, and if anything stays in there to long, it will be covered in barnacles
    1989 Kawasaki X2
    2005 Yamaha XLT1200
    Jul 2010
    Vancouver, BC
    May 24th:
    Down at the dock:
    Fitting the jugs:
    Bolting on the hinges:
    And it floats!
    Next on the list, bolt up the winch and build the deck for the dock box (will be going diagonally across the corner)
    -dg
    2004 SXR 800
    Frequent Poster Waveblaster16's Avatar
    Jun 2009
    St. Louis MO
    Just a question, how come no carpet on the bunks?
    1996 1100 zxi - stock other than premix
    1994 Waveblaster - 760 engine, protec pipe, protec head, dual 44 sbn's, solas impeller, groovy ride plate, protec scoop grate, aluminum waterbox
    1986 X2 - in pieces...
    www.fatmaxracing.com - Buy a poster!
    Frequent Poster hutchej's Avatar
    Jun 2007
    Toronto, Canada
    Also what type of carpet will be durable yet not mark the bottom of the hull? I have a couch and a drive up ramp I use p-edging on and was looking for something with less friction.
    Hutch
    '97 - GSX - Stock, mint condition
    '96 GSX, full engine rebuild, custom paint job
    "Life's tough, get a helmet"
    Jul 2010
    Vancouver, BC
    Quote Originally Posted by Waveblaster16 View Post
    I'm going to add carpet to the bunks and the 2x6s at the back, forgot to mention that. There's a place that manufactures trailers around here, going to see if I can get some trailer carpet from them, I'm hoping they'll have some scrap clippings I can take for free.
    -dg
    2004 SXR 800
