1988 650sx - Black and Metal - Page 3
Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 115
    I dream skis EngineerJon's Avatar
    Sep 2010
    Michigan
    Re: 1988 650sx - Black and Metal
    Almost There:
    Here a few shots of the curent state of the build. Hitting the water this week.
    Resident Guru dkfootball67's Avatar
    Feb 2011
    Delton, MI
    looks great man, cant wait to see it in person
    87 JS300 550 motor, 44 carb, K&N Flame Arrestor, Rule Bilge Pump, WestCoast Pipe, Primer Kit, PJS Head (195PSI), Pole Spring, Precisions Intake Grate, 15.5 Scat Trac Prop, Bored Nozzle,0 Degree Blowsion Bars,ODI lock Grips, Bulk Head Brace, BlackTip
    2007 YFZ450 Race Quad
    Rage motor, 480BB Stroker, Stage3 HotCams, Ported, Race head, Rossier full exhaust, LoneStar +2 AArms, Elka Stage4 shocks, and a whole lot more
    Rode Hard and Put Away Wet!!!- Life Quote
    PWCToday Guru SIMPSON's Avatar
    Jun 2010
    Concord, NC
    nice, i have almost the exact same setup as you. It's lookin good
    Sep 2010
    Michigan
    Quote Originally Posted by SIMPSON View Post
    Yeah I see that! Post some larger pics of your ski, I'd like to check them out. How did that flat black lay out when painting?
    Jun 2010
    Concord, NC
    it was allready painted black when i got it it's being repainted metallic vivid blue right now heres the link to the thread
    http://www.pwctoday.com/f72/1990-650...ds-310764.html
    Frequent Poster Timmer's Avatar
    Mar 2010
    Pensacola,FL
    Nice job. Im about to start my 650 build. Where did you get your handle pole from?
    Sep 2010
    Michigan
    I picked up the handle pole on here from a member, he was selling it for a friend. They pop up every now and then on here. It needed a lot of work to make it look nice, and new bushings from exploreron20s along with shaping and turfing the pad finished it off nicely.
    Sep 2010
    Michigan
    Firstr ride today! The ski was quicker than I anticipated, top speed was almost too much, but I am sure I will get used to it. The prop seemed to work well, I need a little bit more bottom end grunt, but the carb settings might not be spot on yet.
    A pole limiting strap is in my future... Once I go a feel for the footholds and attempted to sub the ski, I over did it and nose stabbed straight down forcing the handlepole a bit further forward that it wanted to go.
    Once I breathed air (versus sucking in water) again, I winced as I looked at my ski expecting the handle pole and mount to be in the water, luckily some bites into the pole and the nose cover loose was the extend of the damage!
    Pics before the ride.
  9. #29
    Sep 2010
    Michigan
    Oh yeah...the hood is a spare, just rattle can black until the matching one is complete.
  10. #30
    PWCToday Guru eddie0899's Avatar
    Aug 2010
    Rocklin CA
    Thats clean!
    300sx 701/144mm conversion in the works
