650SX Fiberglass Resin Question
Results 1 to 10 of 11
    Aug 2009
    Detroit
    I want to use polyester resin since it is SMC, right? So will the Bondo brand polyester resin available at any discount auto supply place work good?
    I dream skis naticen's Avatar
    Feb 2010
    Wilmington, NC
    Re: 650SX Fiberglass Resin Question
    Other way around.
    http://www.pwctoday.com/f100/1986-x2...ld-264408.html
    It's lengthy but post 64 starts talking about it and then 111 shows a good test.
    Top Dog
    Nov 2010
    By the famous windmills
    No u need a epoxy resin if u need jst a lil bit i have 1/2 a gallon of each part (epoxy and hardener ) id sell u let me know
    Happy???
    Aug 2009
    Detroit
    OK, but why is the Evercoat SMC resin that Blowsion slaps a sticker on a polyester resin?
    http://www.blowsion.com/products/206...quart-kit.aspx
    http://www.evercoat.com/productDetail.aspx?pID=16
    "SMC resin is a polyester-based resin used for repair of SMC and fiberglass panels and parts. More effective on SMC than conventional fiberglass-type resins."
    I dream skis EngineerJon's Avatar
    Sep 2010
    Michigan
    It sounds like this product is formulated for use on SMC, but I wouldn’t recommend it. Epoxies are definitely the way to go, and just as easy or easier than polyester resins. They can be sanded and have a lot less smell than polyester resin. SMC has release agents mixed throughout it which is why you need epoxy to bond to it, the polyester resin can’t maintain an ionic bond; it would be a mechanical bond with anything it can grab. Depending on what you’re repairing, I recommend leaving it rough if possible to keep the surfaces exposed for the epoxy to bond to, and then sand it down. Flame treating with a blowtorch helps also to close off the release agents.
    PWCToday Guru Escobar's Avatar
    Aug 2010
    NC
    check out duraglas, its good stuff too.
    1988 Kawasaki X2
    1989 kawasaki 650sx '97 750 big pin conversion
    1991 Kawasaki 550SX '95 750ss conversion
    1998 Seadoo XP Limited --FOR SALE
    Jan 2017
    Cluj
    Quote Originally Posted by Escobar View Post
    Thanks for the tip. I'll give it a try.
    ______________________________
    Dumitru
    Also see fiberglass panels
    Us COMPOSITES is the place to go for all your epoxy needs.
    Dec 2016
    Portland
    I've always used West Systems epoxy resin...always had good results.
    Mar 2018
    CA
    Quote Originally Posted by candysucker View Post
    I have also used West Systems with good results. Used it to patch some js550's that were cracked all the way through in the usual spots. 2 seasons on the repairs with no issues.
