2007 vx cruiser water spout weak
Results 1 to 10 of 12
    May 2011
    texas
    Hello everyone,
    I have a 2007 Yamaha, VX Cruiser and the water spout on the back platform is not shooting as high as it used to be or suposse to be. I will like to know if there what's wrong with it? I cehceked and is not clogged or anything. I took it to the shop and asked the service supervisor and the owner of the shop about it. They both said is nothing. A week later my wife took it to get it winterize and she asked the same question. They told her that it might be the pump or the wear ring (something like that she couldn't explained to me). Any help PLEASE. It has 62 hrs of use and I had since brand new. I will like to know how I can fix it. So as soon I get out of Iraq and go home I can take it to the lake. Thank you.
    PWCToday Regular JIM'S PERFORMANCE's Avatar
    Jan 2004
    palm harbor, fl
    Re: 2007 vx cruiser water spout weak
    Quote Originally Posted by The Rican View Post
    Hello everyone,
    Probably a kinked hose It's not a pump or wear ring because if it was it would cavitate like crazy and would not get to top speed.
    JIM'S PERFORMANCE
    727-365-5132
    Jun 2009
    Ontario
    I just want to know if you made your wife hold the tape measure to check the spout height while you hit the throttle
    May 2011
    texas
    No but thanks for the idea.
    May 2011
    texas
    Thanks JIM
    PWCToday.com Is My Home Away From Home Slowstang305's Avatar
    Jun 2008
    North Miami Beach
    Just disconnect the spout all together, its useless. Is the ski shooting out water from the side when you ride?
    PWCToday Regular nuckinfuts's Avatar
    Boston
    I had a piece of seaweed fit perfectly up the tube so that hardly any water was coming out. It was like a one in a million chance it would happen like that.
    I should have played the lottery that night.
    For your problem, it might just be clogged. Do you have an air hose? Shoot some air into the tube and see if that doesn't clear what ever is in it. That is, if nothing is kinked that you can see....
    May 2011
    texas
    Yes, there is waterr coming out from the side. And I already tried the air hose thru the spout. Thanks for the advise I will check it again
    Jul 2007
    Louisville, KY
    I turn off my
    I dream skis pbrstreetgang's Avatar
    Feb 2009
    Mt Laurel NJ
    Air pressure may not get it......try a coat hanger.
    -____________________________
    2010 FX HO
    "Its never too late to have a happy childhood"
