Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Mar 2010
    sc/nc
    Piston/cylinder wall clearance pjs T-3 550
    Curious what the clearance should be.I was thinking .008 - .010.I have a set of Dycorp twins and a mrd mechanical fuel injection system I plan to try to use for this set-up even with all the bad press.It will be running forged pistons.I have yet to aquire a cylinder and head.I'm wondering what compression is going to be healthy with this set up.The cylinder i'm looking at is new and includes new pjs pistons @ the standard bore,But the owner is saying the piston-cylinder wall clearance is .015 which seems like a lot.Is it possib;e that a full tilt race T-3 engine would need that much?Thx for any input.
    resident guru 440duster's Avatar
    Jul 2010
    Reno
    Re: Piston/cylinder wall clearance pjs T-3 550
    forged pistons require more clearance automotive world because of their expansion characteristics, i would think the same for two strokes but cannot say for sure.
    1984 JS 440
    1990 Superjet 650
    -It is impossible to argue with ignorance-
    Mar 2010
    sc/nc
    I'm aware of that.Just as boats/watercrafts require additional clearence than land engines if they pull in continues fresh water.From what I know cast pistons need .003-.006 and forged need .005-.008 or abouts on marine engines.But a very righ revving,high compression need more because of heat,etc.
    i would go in the .008 to .010 range.
    email watcon@watcon.com
    Please visit our web sites
    Jul 2010
    Reno
    i never know what is the same as 4 stroke stuff. i suppose it really depends on what rpms you would be running and for how long at a time for the .015 to be ok. seems .008-.010 is the way to go
    1984 JS 440
    1990 Superjet 650
    Mar 2010
    sc/nc
    Hey John I sent you an email about those parts just now.Thx again
    Mar 2010
    sc/nc
    As I said I agree with you and john totally.Imo .015 would cause piston slap and possible piston breakage.Has anyone actually ran this much without issues?I wonder why this cyliner has been set up like that.Btw It's suppost to be one of jacobs back up cylinders.
    Quote Originally Posted by 440duster View Post
    my carbed T-3, with 180 psi is at .008
    Top Dog Romoland Jet Rider's Avatar
    Jun 2009
    romoland, CA
    dont weiscos have a larger clearance?
    and did you receive the pipes and mrd yet?
    RyAn
    Mar 2010
    sc/nc
    Yes they do require more clearance as they are forged. I did get that today,Just hadn't got around to emailing you.Everything looks good.I'm hoping to drop off the pipes and the broken nut/pump driver to my machinist tomarrow.Thx again!
    Quote Originally Posted by Romoland Jet Rider View Post
